Author Topic: RNS510 Buttons  (Read 17837 times)
Offline skard
  • -Receive: 245
Re: RNS510 Buttons
« Reply #15 on: November 28, 2016, 09:04:09 pm »
That's exactly the page I was about to post. Best to avoid a firmware modded to avoid battery drain. You'll need to find the procedure for starting a downgrade.
You might lose maps and music on the hard drive doing this, but got to be worth the risk at this point. If this doesn't work, then go back to 2760 but that will 100% wipe your maps.
It is definitely not a D unit so 4020 is about as high as it could go.
Good luck
Offline Pashka
Re: RNS510 Buttons
« Reply #16 on: November 28, 2016, 09:09:29 pm »
It is A,B or early C version. Use modified file. I think it is Can issue. So wires or faulty mainboard.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #17 on: November 28, 2016, 10:19:18 pm »
It's in a April 08 car. I've downloaded both files. I'll use the modified file. If it is the LCD board been quoted £120 to replace it.
Re: RNS510 Buttons
« Reply #18 on: November 28, 2016, 10:31:43 pm »
Mine is the a version and got mine updated with new maps on,not sure what firm ware it's on
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #19 on: November 28, 2016, 10:44:09 pm »
Press and hold the setup button to get to the hidden menu. Will tell you there.
Re: RNS510 Buttons
« Reply #20 on: November 28, 2016, 10:52:14 pm »
Offline Pashka
Re: RNS510 Buttons
« Reply #21 on: November 29, 2016, 09:34:43 am »
It is not the LCD board, illumination works on your video, dissapears later.
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #22 on: November 29, 2016, 11:21:44 am »
So all points to firmware?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #23 on: November 30, 2016, 07:07:30 pm »
Not a lot happening
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #24 on: November 30, 2016, 07:11:40 pm »
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #25 on: November 30, 2016, 07:16:12 pm »
What's SWL image?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #26 on: November 30, 2016, 07:18:01 pm »
Great it's just hanging now! Not doing didly squat
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #27 on: November 30, 2016, 07:21:34 pm »
Can this be done via SD card
Offline Pashka
Re: RNS510 Buttons
« Reply #28 on: November 30, 2016, 07:31:18 pm »
Nope, so have you rewritten firmware or not? Your pics are the first steps of rewritting the firmware.
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #29 on: November 30, 2016, 07:35:20 pm »
Nope not doing anything. The file I'm using is .iso currently (the modified file) But there is also a .nrg file. I'll try that.
