Author Topic: RNS510 Buttons  (Read 17820 times)
Offline Pashka
Re: RNS510 Buttons
« Reply #60 on: December 03, 2016, 11:04:12 am »
Yeah, not worth fixing for 200 when the unit like yours cost around 250. Better sell this one for the spares, you will get 100-150 and get a LED one.
« Last Edit: December 03, 2016, 11:05:47 am by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #61 on: December 03, 2016, 03:25:42 pm »
Ok thanks. Are new units just plug and play?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #62 on: December 03, 2016, 03:36:53 pm »
Found one for £450 including the Bluetooth module.. Where does the module fit?
Ninja
Re: RNS510 Buttons
« Reply #63 on: December 03, 2016, 06:45:16 pm »
Devils advocate. What if it's not the unit at fault?
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #64 on: December 03, 2016, 07:07:36 pm »
What else could it be? Would VCDS help?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: RNS510 Buttons
« Reply #65 on: December 03, 2016, 08:10:33 pm »
You can consider fitting the radio in another car. If your car came with the RNS-510 from factory your CAN is a rev L, which is compatible with newer firmwares, so that shouldn't be the problem. Just writing this because if the radio doesn't know when the car lights are turned on, it won't turn the lights on of its buttons.
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #66 on: December 03, 2016, 08:30:56 pm »
Terminal 58 is getting a signal..
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #67 on: December 04, 2016, 12:12:32 pm »
Right I'm going to buy a new unit.
Re: RNS510 Buttons
« Reply #68 on: December 04, 2016, 01:04:50 pm »
Yeah think that will be the best option and to save your sanity :signLOL:
Offline V6nutter
  • -Given: 17
Re: RNS510 Buttons
« Reply #69 on: December 07, 2016, 05:54:49 pm »
New RNS fitted. Working perfectly
Re: RNS510 Buttons
« Reply #70 on: December 08, 2016, 07:19:58 pm »
that is good news :happy2:
