Author Topic: Wing mirror switch possible fault  (Read 1640 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: November 27, 2016, 04:23:30 pm »
Hi guys not often I post up an issue but here's one.
My Chinese wing mirror controller seems to now want to control both mirrors from the right hand side although the left controls it's own side?. Could the switch be faulty? has anyone had an issue like this before?. I'll fit my old switch in to check if that works okay and report back.
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Wing mirror switch possible fault
« Reply #1 on: November 27, 2016, 05:30:04 pm »
I'm pretty sure that's normal. Same on mk4s iirc.
Offline 99hagued
« Reply #2 on: November 27, 2016, 05:35:32 pm »
Can't you adjust it to operate single mirrors from the highline display menu or vcds mate
Offline barelyrelevant
« Reply #3 on: November 27, 2016, 05:42:32 pm »
This is the default setting I believe, as said I think you can turn it off in the high/midline settings.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: November 27, 2016, 06:30:33 pm »
never did this before I assure you  :confused:
i have a high line clock but never knew it could be set from that as I don't have a multi function steering wheel. I'll give Vcds a shot but I haven't changed any setting in a good while and only fitted these switches 2months ago and they worked fine up until this afternoon.
never knew these has a default setting TBH but knownit can be set in vagcom.
Thanks guys
Offline 99hagued
« Reply #5 on: November 27, 2016, 08:51:14 pm »
U can get into the menu by using the buttons on the side of the indicator stalk mate, think you hold the up or down button while stationary
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: November 27, 2016, 11:25:39 pm »
will try this thanks as I didn't know as mine was originally a midline clock. Still don't understand why it changed all of a sudden.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: November 29, 2016, 04:30:22 pm »
Solved the mystery of the weird switch problem.
I changed the setting in early 2016 and some how it's only just registered the program  :thinking: so on vagcom last night and unchecked synchronise mirrors and hay presto  :smiley:
Will need to reset it all when I fit my new power folding puddle light ones on.
