Author Topic: DSG Reset - Portsmouth Area  (Read 997 times)
Offline david85williams
« on: November 28, 2016, 09:13:47 am »
Hi all,
Is there anyone local to me who can perform a DSG reset? My local VW specialist is always too busy and can't see me until mid December...
I was hoping someone could simply help with a quick plug in a reset? Is it that simple?
I had an issue with the auto holding onto gears too long. I cleaned a intermittent ABS sensor which cured that problem but the pull away could be smoother. I believe a DSG reset could resolve this problem.
Offline patpong_pete
Re: DSG Reset - Portsmouth Area
« Reply #1 on: November 28, 2016, 11:33:38 pm »
A Dsg reset with vag com is 1st choice
but need to change the oil in the dsg is should be done 40k and 80 k
if still not wright could be mentronics or clutch packs has 2 clutch packs
try new oil and reset dsg
let us know how it pans out good luck
« Last Edit: November 28, 2016, 11:35:40 pm by patpong_pete »
« Reply #2 on: November 29, 2016, 07:52:32 am »
Thank you for the reply. I believe the oil was changed within the last year. The pull away problem only seems to occur when the engine is warm. Cold pull aways are fine.
