Author Topic: Side Skirt adhesive  (Read 1959 times)
Offline Nodz
  • -Given: 73
  • -Receive: 103
Side Skirt adhesive
« on: December 03, 2016, 12:41:55 pm »
My cars is gonna be going back to standard over the next few weeks so I'm going to be putting the old side skirts back on.
I remember when I got my R32 ones they had an adhesive strip along the top, double sided foam iirc. I did have a look on ECP but couldn't find anything. Found this on maplins, Is this stuff right for the job or is there something better for it?
http://www.maplin.co.uk/p/double-sided-foam-tape-12mm-x-10m-n91al
« Last Edit: December 04, 2016, 09:04:18 am by Nodz »
Offline MrVW1589
  • Eat Sleep VW
Re: Side Skirt adhesive
« Reply #1 on: December 04, 2016, 01:07:51 am »
hi mate
I'd definitely recommend Tiger Seal, its designed for this type of application and have been recommended before by a few diff people  :happy2:  heres a link for you:  http://www.ebay.co.uk/itm/U-pol-Tiger-Seal-PU-Adhesive-Sealant-White-Tigerseal-Bond-Body-Panels-/172301173084?hash=item281df3415c:g:6ngAAOSwawpXqzZG
hope this helps!
Dave
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #2 on: December 04, 2016, 10:41:39 am »
4ndy
« Reply #3 on: December 04, 2016, 12:39:23 pm »
I use the 3M stuff because its free from work :happy2:  Make sure you get both surfaces clean.
Offline TAPPY
  • -Receive: 56
« Reply #4 on: December 04, 2016, 02:34:46 pm »
Same but I've used the cheap stuff and it's pants
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: December 04, 2016, 03:36:44 pm »
Get the 3m stuff mate like this
http://pages.ebay.com/link/?nav=item.view&alt=web&id=182327298138&globalID=EBAY-GB
When I first looked at this stud I was like no way  :signLOL: but when I used the stuff I was shocked at how strong it was and as long as both surfaces are clean it will do fine.
4ndy
« Reply #6 on: December 04, 2016, 04:44:22 pm »
should have said "IPA" for cleaning :happy2:  ebay cheap
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: December 04, 2016, 08:04:04 pm »
Cheers guys, I'll get some of the 3m stuff on order
