Author Topic: Canbus unplug and reconnect  (Read 1015 times)
Offline tokomak
« on: December 07, 2016, 10:56:34 pm »
I'm wanting to upgrade away from my RCD300, however I need to check my Canbus version before I do anything, I need to take it out to check the part number as I don't have VCDS or anything similar. my question is if I remove the canbus and put it straight back in after checking the part number, will that cause any error message or warning lights that I would need vagcom to remove?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=oubia1gdd16078d880bgdmroot&/topic,19740.0.html
Re: Canbus unplug and reconnect
« Reply #1 on: December 07, 2016, 11:10:30 pm »
Will be fine. Just keep the ignition off
