Author Topic: Tornado red edition 30 #2061  (Read 11548 times)
Offline Danno84
  • -Given: 26
« on: December 08, 2016, 07:19:41 pm »
My old pride n joy
I had the want for a petrol gti for a while now, and thought I would treat my self to an early Christmas present,
A tornado red edition 30,
Found this one fairly local to me and fell in love, it needs a bit of tlc but drives absolutely spot on, and has full history which was important to me,
Jobs to do,
Paint correction,
Refurb the wheels,
High level brake light isn't working,
Not looking to heavily modify this, think my plans inc 40mm h&r springs, and a miltek exhaust,
« Last Edit: January 02, 2017, 08:03:42 pm by Danno84 »
Offline golfmck1980
Re: My new car: tornado red edition 30
« Reply #1 on: December 08, 2016, 08:55:37 pm »
Good luck with yr new purchase a great colour choice of eddie but then thats cause i have 1 myself. I wld suggest u shld deffo get a remap with that engine its mental not too.
Edition 30 num 859
Offline Danno84
  • -Given: 26
« Reply #2 on: December 08, 2016, 08:57:12 pm »
I am tempted to re map it
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #3 on: December 08, 2016, 09:06:42 pm »
Do the hardware before you get the remap. Pointless going Stage 1 and then deciding you want more - any hardware mods will need the appropriate map to get the best out of them. A good turbo back exhaust will bring it to life, and an uprated fuel pump will bump the low-mid torque nicely. Those two mods, then a map, and you're sorted (if you want to keep things subtle).
Offline samiul11
« Reply #4 on: December 09, 2016, 02:16:41 pm »
think you can only get 30mm springs for these
Offline dontfollowme
« Reply #5 on: December 09, 2016, 06:24:42 pm »
OP, did you get that from a dealer? If so, which one?
Offline Danno84
  • -Given: 26
« Reply #6 on: December 09, 2016, 06:59:50 pm »
H&r list a 40 mm kit :)
Offline Shoy1980
« Reply #7 on: December 09, 2016, 10:22:37 pm »
For the Gti it's 30mm
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #8 on: December 09, 2016, 10:32:39 pm »
Very nice :happy2:
Offline Danno84
  • -Given: 26
« Reply #9 on: December 11, 2016, 03:32:17 pm »
You are right it is 30mm for gti my apologies:)
Offline CP-Performance
« Reply #10 on: December 11, 2016, 04:16:42 pm »
ST also do a 30mm kit for these, still retaining a decent level of comfort over most road surfaces.
Instagram chr1spick
www.cp-performance.co.uk
Offline Danno84
  • -Given: 26
« Reply #11 on: December 11, 2016, 07:52:27 pm »
Been looking at the st ones, made by kw
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #12 on: December 11, 2016, 08:28:07 pm »
I can vouch for the H&R springs. Nice drop and decent ride. If I was ever looking at coilovers I'd consider ST, they're basically what Weitec used to be and the set I had on an old car were decent.
However, when it comes to springs H&R are tried and tested, whereas ST/KW springs would be more of an experiment - you just don't know how the car's going to sit, and once they're on there's no adjustment. By all means try them though. They might be good.
Offline Danno84
  • -Given: 26
« Reply #13 on: December 11, 2016, 08:57:13 pm »
Thanks for the advice  :happy2: think the h&r's is where my money will go, as long as the ride isn't too harsh,
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #14 on: December 11, 2016, 09:04:48 pm »
They're all good as long as your dampers aren't shot. When I fitted mine (on standard dampers) I could barely tell the difference.
They will wear the dampers faster than standard springs, purely down to the reduced travel making the dampers work under more compression, but that'd be exactly the same case as any spring that dropped the car 30mm.
The main consideration for me was how it sat, and I'm happy with it. In the future there are plenty of options for fitting new uprated/shorter dampers that will work even better with shorter springs like the H&Rs.
