Author Topic: Eibach pro kit picture request please.  (Read 3951 times)
Offline Duffmeister
« on: December 10, 2016, 06:15:46 pm »
As the title really, I'm thinking of adding the pro kit as I've heard its a better ride than stock and a touch lower.
If you're running the pro kit could you post a picture so i can gauge how the car sits on these please.
I've ran the pro kit springs on two previous bmws and only got a 20mm drop, has anybody measured before and after on fitting of theirs?
Thanks in advance.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Eibach pro kit picture request please.
« Reply #1 on: December 10, 2016, 09:18:54 pm »
Eibach doesn't sell Pro-Kits for GTI in Europe. Just for GT/GT Sport and other normal versions of Golfs. If want Eibach springs you can fit Sportlines which lower ~30 mm. Plenty of cars in the forum have them, just like H&R -30 mm springs. I have the Pro-Kit on my GT Sport and H&R -30 mm on my Ed. 30.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: December 11, 2016, 09:05:51 am »
This is a long time ago when my '07 sat on Sportlines...about or nearly 0.5" lower than Prolines...
« Last Edit: December 11, 2016, 07:52:25 pm by ROH ECHT »
Offline Duffmeister
« Reply #3 on: December 11, 2016, 11:29:53 am »
[/quote
I'm getting even more confused now, in the mods section on this forum Eibach pro kit is clearly available and on about a dozen different websites. Does the pro kit exist or not of should I go H&R, I wanted the pro kit as I'd heard it was more comfortable than stock.]
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: December 11, 2016, 11:41:14 am »
I prefer to consult the brand's catalogue and search the correct part number for my car, not shops catalogues. :smiley:
I've seen many shops selling Pro-Kits for mk5 GTI but the only correct part number you can found is on the American Eibach catalogue. The American mk5 GTI has the same drop as the European mk5 GT/GT Sport: -15 mm. The European mk5 GTI has a -20 mm lowered suspension.
http://web2.carparts-cat.com/default.aspx?230=1&36=0&35=2299&32=18387&34=0,2047566&14=4&10=348AB45A21734C7DB4E9340C83AFB999279015&12=130
You can find 2 different part numbers only for Eibach Sportlines for European mk5 GTIs, that correspond to cars with or without DSG. :wink:
I bought my Ed. 30 with Sportlines and I changed to H&R -30 mm. I also fitted Koni Sports instead of the OEM dampers and the ride comfort improved considerably compared to what the car was before.
Offline Duffmeister
« Reply #5 on: December 11, 2016, 01:35:29 pm »
Would you recommend the H&R over the Eibach then?
If so which ones?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: December 11, 2016, 05:36:34 pm »
I prefer the H&R and for GTI there's only one correct part number which lower 30 mm. The springs are blue.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #7 on: December 11, 2016, 07:51:54 pm »
I went from Eibach sportlines to H&R SuperSports, but the H&R SS's aren't available there.  :doh:
I thought Eibach was more comfy a street ride than the SS's...the SS's being better track equipment.
Offline RBS
  • -Receive: 47
« Reply #8 on: December 12, 2016, 10:59:26 am »
Go for the H&R springs :wink:
« Reply #9 on: December 12, 2016, 12:24:01 pm »
Would you put the harsh standard ride down to the OEM dampers?   The standard spring rates feel about right to me, just harsh damping.  The germans love their ridiculously firm high speed compression damper valving.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10 on: December 12, 2016, 12:28:14 pm »
Yes, the OEM dampers were in good condition. Before removing them I thought they were shot. Fitting Koni Sport well adjusted or Bilstein B8 would be ideal to get the most of the springs.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11 on: December 14, 2016, 05:23:25 am »
I had 22k miles when the sportlines went on with the oem dampers. I put the H&R on at 58k miles along with Bilstein B8's and found 3 of the 4 oem dampers were leaking. I would suggest new and upgraded dampers when sport springs are installed. I didn't because I knew I would get more miles from the oem dampers that only had 22k on them when the first set of springs were installed.
