Author Topic: Mk5 GTi - known faults  (Read 5181 times)
Offline courgette
« on: January 26, 2010, 08:42:13 am »
Hello All
I'm considering buying a 55-plate GTi.
It's done 40k miles, which has included several track days.  It's had a cambelt and ABS pump.  Keen to hear from you what I should be looking for when viewing/driving car + to get an insight into common/known faults etc.
Many thanks
Courgette
Offline Poppa Dom
Re: Mk5 GTi - known faults
« Reply #1 on: January 26, 2010, 09:21:57 am »
If it is at 40k, has it had the 40k service done - quite a big one. Is the car manual or DSG - DSG oil needs changing at 40k. If it has been looked after well and been tracked it may have been changed early - check the logbook, if it has it's a good sign of a caring owner! If it has been tracked, check brake set up carefully - rotor/pad wear. Some early GTI's did have steering rack issues so check this out too. Go through all electrics thoroughly for piece of mind, check boost/dv. Ideally if there is someone with VCDS get them to scan for codes when viewing car, doing some logging if a test drive becomes an opportunity. Not sure what the interval on the cambelt is, seems a bit early? Am sure others will step in.
« Reply #2 on: January 26, 2010, 09:27:03 am »
welcomes  :drinking:
Offline courgette
« Reply #3 on: January 26, 2010, 09:48:26 am »
It's a manual.
It has been serviced at least twice.  Cambelt done at 40k in accordance with schedule.  It's on it's 2nd set of oem brakes.
What would be a fair price privately?  It has cloth with xenons?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #4 on: January 26, 2010, 09:57:54 am »
40k miles is early, service book says 100.000 miles i believe?
Known weak spots engine wise:
DV
PCV
Aircon pump of the brand Xezel
coilpacks/spark plugs
from the top of my head, remember the are not often occuring just some things that are known to be weak, i would,'t trade my 2,0 TFSI for anything,,,, almost  :laugh:
Over the top mod list ;o)
Offline courgette
« Reply #5 on: January 26, 2010, 04:15:55 pm »
Cambelt is every 4 yrs, not 100,000.
Waterpump is normally changed at 2nd cambelt change, so at 80k.
« Reply #6 on: January 26, 2010, 05:16:40 pm »
Welcome along matey  :pomppomp: :wink:
  • -Given: 243
  • -Receive: 154
« Reply #7 on: January 26, 2010, 05:25:25 pm »
In this part of the world where we use the metric system, it's 180.000km  :P mine got changed at 160.000km including waterpump change  :wink:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #8 on: January 26, 2010, 09:17:46 pm »
Might be worth checking the mount attached to the subframe supporting the exhaust.  They can break under hard acceleration, etc.
