Author Topic: MDI Sound Quality  (Read 1393 times)
Offline AlexR1823
MDI Sound Quality
« on: December 20, 2016, 05:10:45 pm »
So I attempted an MDI retrofit at the weekend, but the sound quality is poor through the MDI box, I know the MP3 files are fine because they play through my dads car perfectly.
I read that swapping pins may be required, I tried swapping the ground pin from 2 to 3 but that did nothing, are there any other possible fixes to this issue?
Also, found this on my-gti if it helps:
http://www.my-gti.com/1328/auxiliary-input-audio-sound-quality-problems-after-changing-head-unit
Re: MDI Sound Quality
« Reply #1 on: December 20, 2016, 11:56:07 pm »
fitted one to mine the other week and it sounds fine
Offline Pashka
« Reply #2 on: December 21, 2016, 08:58:10 am »
Check the loom for breaks.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #3 on: December 21, 2016, 05:08:55 pm »
Try going into the settings, somewhere the input is set to low, try it on medium or even high. see if it makes a difference, it did on mine.  :happy2:
Offline AlexR1823
« Reply #4 on: January 01, 2017, 04:51:05 pm »
Checked the loom and can't see anything obvious.
Also there is no option for AUX input level? Checked in all the settings and cant find anything.
