Author Topic: Standard wheel bolts size?  (Read 9600 times)
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« on: December 22, 2016, 06:25:52 pm »
I need to get some spacers as new wheels will be on soon. At a guess 8 or 10mm
What size width and diameter are the standard bolts? It's an edition 30 with pescara wheels at the moment.
Also do they do hubcentric spacers shorter than 15mm?
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Standard wheel bolts size?
« Reply #1 on: December 22, 2016, 07:12:45 pm »
M14x1.5, 28mm thread length. Radius seat for OEM wheels, 60 degree taper for most aftermarket wheels.
Add whatever width spacer you use to the thread length. You might not be able to buy the exact length bolt you want. Just use your head. Too little thread would be unsafe, too much might foul something.
H&R used to do an 8mm spacer with the spigot for the wheel - strictly speaking, you mean wheelcentric. Impossible any smaller.
Offline slix
  • -Receive: 38
« Reply #2 on: December 22, 2016, 08:01:15 pm »
Ok thanks. It's annoying that spacers are so god damn expensive. Ordered some 8mm with 35mm bolts.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #3 on: December 22, 2016, 08:31:57 pm »
No probs. Yeah I've always stuck to known brands like H&R, Eibach etc. You do pay a premium, but then you know they'll fit properly and not corrode.
