Author Topic: Help needef whats this part re forge dump valve  (Read 2103 times)
Offline bradh
« on: December 26, 2016, 10:43:30 am »
Guys just removibg this forge dump valve kit off my gti and have noticed last owner has tapped into a different vac line is this an optional extra part or normal one
Will i be ok to just blank pipe off
Sent from my SM-G920F using Tapatalk
Offline v4rley
  • -Receive: 104
Re: Help needef whats this part re forge dump valve
« Reply #1 on: December 26, 2016, 01:44:50 pm »
That's a boost tap. You can remove the whole thing rather than blanking it off. Unclip the corrugated pipe and the there is a 'circlip' at the other end.
Offline bradh
« Reply #2 on: December 26, 2016, 04:47:52 pm »
boost tap hmm does that mean i can get my self a boost gauge and plumb it in there??
quite like finding extra things on this car iv brought :)
Offline barelyrelevant
« Reply #3 on: January 01, 2017, 11:18:54 pm »
Can't see any reason why not, the Forge DV uses vacuum/boost to control the solenoid so it must be a good enough place to take a reading.
Why are you removing the Forge?
Offline bradh
« Reply #4 on: January 01, 2017, 11:21:12 pm »
Didn't like the tshhhh sound :)
« Reply #5 on: January 01, 2017, 11:48:39 pm »
Have you got a photo of it? Some people add a spacer into them which makes that horrible sound. This can be removed for a more subtle sound, although aftermarket air intakes can be noisy, even with a OE DV.
Offline bradh
« Reply #6 on: January 01, 2017, 11:56:52 pm »
It was the forge kit sold it on now :) fitted stock item
