Author Topic: Wheel bearing on way out but which one?  (Read 5177 times)
Offline v4rley
  • -Receive: 104
« on: January 01, 2017, 03:06:17 pm »
Have a whiring sound when driving sounds like it's a wheel bearing coming to the end of it life, only issue is I don't know which one  :rolleye:
Does anyone have any advice or guidance how to diagnose which one it would be? I have jacked each corner and spun each wheel and checked for play but not managed to find anything that way..
« Last Edit: January 01, 2017, 03:15:02 pm by v4rley »
Offline chigmuss
Re: Wheel bearing on way out but which one?
« Reply #1 on: January 01, 2017, 07:52:41 pm »
That's normally the way I'd determine which one bud. You sure both aren't going?
Offline Cr33D
« Reply #2 on: January 01, 2017, 09:50:56 pm »
I would firstly lift up your car and look for physical play by rocking your wheel to see is there any play in there...
There should be none.
You can also spin a wheel and listen is there any grinding sound coming out.
This are first things you can do on your driveway.
Offline barelyrelevant
« Reply #3 on: January 01, 2017, 11:16:07 pm »
I just had my offside rear wheel bearing changed as it was very noisy.
Best thing to do it jack the whole rear up and then spin the wheels one after the other so you can directly compare the two. I found you had to give them a bit of welly to get them spinning fast enough that you could hear it.
Once the wheel and disc were off you can spin the bearing on it's own very easily, sounded terrible. I should note there was barely any play in the wheel, but still very noisy.
Offline v4rley
  • -Receive: 104
« Reply #4 on: January 02, 2017, 07:46:19 am »
Ok thanks people. Have already jacked spun and checked for play but think I need to try again and spin a bit faster this time  :grin:
Offline Lewo
« Reply #5 on: January 03, 2017, 05:55:45 pm »
Did u guys replace with vw bearings or another make?
Offline GTI8v
« Reply #6 on: January 03, 2017, 07:19:22 pm »
I found if whilst driving you turn left (fast enough to have the bearing whining) and the noise reduces or stops then it's one of the left ones.
If you turn right and it goes then it's usually right hand side, something to do with the load being lessened on that side therefore reducing the friction.
Hard part is working out front or rear  :signLOL: I had one whining a couple of months ago, sometimes sounded like it was from the front.... it wasn't
hth
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
« Reply #7 on: January 03, 2017, 08:59:38 pm »
I just went for the more expensive of the two option on Euro Car Parts.
Offline v4rley
  • -Receive: 104
« Reply #8 on: January 03, 2017, 09:26:04 pm »
Thanks people. Have just re spun the wheels faster and appears to be o/s/r  :happy2:
Offline Lewo
« Reply #9 on: January 04, 2017, 04:42:50 pm »
Ive ordered some SNR bearings from ECP for £68, VW are £130odd according to the old invoices that came with the car.
I had to order a 30 & 32mm as I dont know what the car has fitted, will return the one not needed.
Offline Adam0604
« Reply #10 on: January 04, 2017, 09:12:26 pm »
It's 30mm dude, did mine only the other month.
Offline Lewo
« Reply #11 on: January 05, 2017, 12:24:57 pm »
Ok mate thanks.
Offline Lewo
« Reply #12 on: January 06, 2017, 02:55:00 am »
How long to change a rear bearing?
Offline Cr33D
« Reply #13 on: January 06, 2017, 08:24:45 am »
Take a wheel out, disc, caliper, shield, bearing. Put back together. Depends in what condition your current parts are.
Sent from my EVA-L09 using Tapatalk
Offline Lewo
« Reply #14 on: January 06, 2017, 03:28:57 pm »
Mate will be doing it for me just wondered on a ball park time if no problems.
