Author Topic: Mk 6 MFSW and C/C  (Read 12643 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Mk 6 MFSW and C/C
« on: January 26, 2010, 08:58:20 pm »
Hi,
I have fitted the mk 6 MFSW and the 1K0-953-549-CH  steeringwheel controlmodule to get the buttons to work, also the C slipring is fitted and the buttons works.
BUT i've lost the communication to the C/C ( cruise control )  :sad1:
My thoughts are, do the 1K0-953-549-CH module support C/C????
Could a possibility be to replace the mk 5 c/c stalk with one from the mk 6 partnr. 1K0 953513 G  (9B9 for black) ??? do the mk 6 fit in the mk 5?
Any thoughts would be appreciated.
Ps i have Darren working on this too  :notworthy:
« Last Edit: March 18, 2011, 07:56:44 am by danishmkvgti »
Over the top mod list ;o)
Offline ollie288
Re: Mk 6 MFSW and C/C
« Reply #1 on: January 26, 2010, 09:00:30 pm »
Darren has been though vag com on my car and couldn't see the problem. Like I said in the other thread if you do come up with a solution I would be interested!  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #2 on: January 26, 2010, 09:21:53 pm »
i've almost bought a stalk for the mk 6  :happy2: let's see how it goes  :drinking:
« Reply #3 on: January 27, 2010, 10:10:35 am »
its to do with the mk6 not using a slip ring right?
wish i knew this before i bought my mk6 wheel!  :driver:
Offline QD MBE
  • -Receive: 102
« Reply #4 on: January 27, 2010, 11:14:49 am »
Apparently the CH module is compatible with the C slipring, and supports Cruise.  However I am not sure if the MK5 Cruise is activated by the same method.
Type I (Compatible to Slip Ring: 1K0-959-653, 1K0-959-653-A)
Lowline
Part Numbers: 1K0-953-549
Supported Features: None
Midline
Part Numbers: 1K0-953-549-A
Supported Features: Cruise Control, Trip Computer
Highline
Part Numbers: 1K0-953-549-B, 1K0-953-549-D, 1K0-953-549-AD, 1K0-953-549-AM
Supported Features: Cruise Control, Trip Computer, Multi-Function Steering Wheel
Type II (Compatible to Slip Ring 1K0-959-653-C and 1K0-959-653-D with Steering Angle Sensor)
Lowline
Part Numbers: 1K0-953-549-E, 1K0-953-549-AE, 1K0-953-549-BM
Midline
Part Numbers: 1K0-953-549-F, 1K0-953-549-AF, 1K0-953-549-AH, 1K0-953-549-AP, 1K0-953-549-BC, 1K0-953-549-BF, 1K0-953-549-BN, 1K0-953-549-BR, 1K0-953-549-CA
Highline
Part Numbers: 1K0-953-549-G, 1K0-953-549-AG, 1K0-953-549-AK, 1K0-953-549-AL, 1K0-953-549-AQ, 1K0-953-549-BD, 1K0-953-549-BK, 1K0-953-549-CC
Type III (Compatible to Slip Ring 1K0-959-653-C and 1K0-959-653-D without Steering Angle Sensor)
Lowline
Part Numbers:
Midline
Part Numbers: 1K0-953-549-CM, 1K0-953-549-CN
Highline
Part Numbers: 1K0-953-549-CD, 1K0-953-549-CF, 1K0-953-549-CH
« Reply #5 on: January 27, 2010, 11:39:49 am »
you have to take some of these VCDS lists with a pinch of salt sometimes.
For example, i know for a fact that AK and AL are not compatible with cruise, highline and MFSW. It cost me £280 that list! haha!
Offline QD MBE
  • -Receive: 102
« Reply #6 on: January 27, 2010, 11:44:10 am »
that is strange Jay.  Usually quite accurate.
have you uploaded 2680?
Offline Norbreck21a
« Reply #7 on: January 27, 2010, 05:03:51 pm »
Jay, I have the "AK" module, cruise, MFSW and highline, and they all seem to work on mine (except the menu button on the MFSW).  :confused:
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: January 27, 2010, 05:43:27 pm »
Ive got Dana looking into this, Jake could you supply me with the coding on your CH controller,  by the way the cruise stalk on the 2005 golf is exactly the same has the 2011 golf exact same part numbers
Darren
« Last Edit: January 27, 2010, 07:00:31 pm by mortygttdi »
  • -Given: 243
  • -Receive: 154
« Reply #9 on: January 27, 2010, 07:18:10 pm »
Darren
Coding i believe ended up being "0000732", the mk. 6 stalk has a different exterior than the mk. 5
« Last Edit: March 05, 2011, 02:01:24 pm by danishmkvgti »
Offline mortygttdi
  • -Receive: 146
« Reply #10 on: January 27, 2010, 07:23:43 pm »
Jake that could be the stalk for the automatic distance control which is on the same stalk has C/C??
part number for that is 1K0 953 513H
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: January 27, 2010, 07:26:04 pm »
That could be the coding.  What are you on at the moment?
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: January 27, 2010, 07:44:01 pm »
Stu I think Andrew has sort of got it on the nail from what I spoke to him reg this,
basically the 2005 golf came out and the optional mfsw has a different layout on the buttons and the layout didn't make use of the menu button instead it had a source button that went to the stereo I would presume??
Any way Im thinking that cos of this the loom to the instrument cluster is different from the steering controller, and to make use of the menu button I would say we need to look at the wiring from the steering controller...I had a look today at mine and there is loads of spaces available on the connector??
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: January 27, 2010, 07:49:29 pm »
Ahh ok, I was just wondering if this part of the coding was correct -
Quote
0xxxx?x: Board Computer / Cruise Control System (CCS)
0 = w/o Board Computer and w/o Cruise Control System (CCS)
1 = with Board Computer and w/o Cruise Control System (CCS)
2 = w/o Board Computer and with Cruise Control System (CCS)
4 = with Board Computer and with Cruise Control System (CCS)
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #14 on: January 27, 2010, 07:52:20 pm »
Ive tried all different combo's of coding but it still wont activate the menu button :sad1:
Darren
