Author Topic: 00779 - Outside Air Temp Sensor (G17)  (Read 3531 times)
Offline dave1814
« on: January 05, 2017, 04:21:51 pm »
Hi all!
Just wondering if someone can help me with the following fault code...
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 962
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0007403
Shop #: WSC 00671 067 57207
VCID: 6ED24880796EDD322B-803A
1 Fault Found:
010 - Open or Short to Plus - Intermittent
My outside temperature reading is crazy on the dash, it ends up in minus figures when I drive the car (when it clearly isn't) and also plays havoc with the A/C!
So far I have tried...
1. New genuine ambient temperature sensor
2. Cleaned all connections
3. Reset the all faults using VCDS
Is it possible this could be a faulty Instrument Cluster? (that's about all I can think of from googling!)
many thanks,
Dave
Re: 00779 - Outside Air Temp Sensor (G17)
« Reply #1 on: January 09, 2017, 04:18:27 pm »
Could be some iffy wiring between the sensor and instruments, especially if the readings are sporadic!
Offline Christiank
  • -Receive: 39
« Reply #2 on: January 19, 2017, 11:06:18 am »
Isn't their a second sensor placed somewhere?
Think I've read a while back someone had same problem as you. Think the solution was a second sensor somewhere that was broken.
Try search google for it.
Regards
