Author Topic: Can thsi bolt be replaced without...?  (Read 804 times)
Offline K9
  • VW LifeStyle
« on: January 05, 2017, 06:45:25 pm »
Hey. A time ago when i swaped oem bushes to WALK  kits and one bolt snapped in the subframe and is now drilled out with the threads, there is a long bolt now sticking thrue the subframe and a locking washer on the topside. Question is now that can i make Aligments and the remove this bolt without caussing the aligment to go crazy again? I'm talking about one of the 16mm bolt tthat is securing the console bush to the subframe.
Thanks!
Re: Can thsi bolt be replaced without...?
« Reply #1 on: January 07, 2017, 04:04:02 pm »
If you don't disturb the other 2 bolts, the alignment won't change  :happy2:
