Author Topic: VCDS needed pls....  (Read 1093 times)
Offline D_Philli_82
VCDS needed pls....
« on: January 08, 2017, 05:17:53 pm »
Hi,
Is there anyone available in either Reading / Swindon to clear a airbag fault on my 07 mk5..? I stupidly disconnected the plug before disconnecting the battery when changing the stereo...! Thanks in advance..!!
MK5 1.9TDI 150Bhp
Offline Cr33D
Re: VCDS needed pls....
« Reply #1 on: January 08, 2017, 06:58:10 pm »
Have a look here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
There is a user from Reading.
If no luck I am based in Portsmouth if you need any help.
Regards
Cr33D
Offline Chris_R
« Reply #2 on: January 08, 2017, 07:44:01 pm »
Also able to help, I have just had mine delivered yesterday and done some coding, fault lookups, logging and clearing - had one before so familiar with VCDS a little.
I am near Bath which is a bit out the way for you - 50 miles each way - if you are still stuck. It may be just as easy to pay an independent like Dialynx a visit who are not far from you to do it for a few beer tokens.
Offline D_Philli_82
« Reply #3 on: January 09, 2017, 12:44:07 pm »
Thanks...I forgot about the VCDS thread..also been to Dialynx before so that's another option...cheers
MK5 1.9TDI 150Bhp
