Author Topic: How To Fix Washer Fluid Dash Light?  (Read 2923 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: January 09, 2017, 10:03:04 am »
My girlfriends mk5 golf has a dash light to refill washer fluid.
The tank is completely full so I imagine it's the sensor.
I have VCDS and tried resetting it and actually turning it off but to no avail.
Only had a quick look yesterday, I imagine the sensor is at the lowest point? Has anyone replaced one before?
Offline mikezs
Re: How To Fix Washer Fluid Dash Light?
« Reply #1 on: January 09, 2017, 12:17:47 pm »
It might be the famous bonnet catch sensor that checks you've opened your bonnet when any of the lights come on. Common fix is to spray liberally with a cleaner (or WD40) and give it a clean out with a brush.
VCDS measure value blocks will be able to check the bonnet sensor and the washer sensor, just need to find the module/block
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: January 09, 2017, 02:05:39 pm »
Bonnet catch is fine. Tested already by leaving bonnet open and coolant cap off. Only registers when bonnet closes.
Anybody else?
Offline Cr33D
« Reply #3 on: January 09, 2017, 05:42:03 pm »
See link below. There is a manual done by Eddie-NL how to add low screen wash sensor.
I am sure you can use it for replacing it.
http://uk-mkivs.net/topic/27803-low-screen-wash-warning-fitted/
Eddie is showing on how to do it via fog lamp grille. I think it's also doable by removing wheel and wheel arch trim.
Hope this helps.
Regards
Cr33D
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: January 11, 2017, 10:39:21 am »
Hope this helps.
Regards
Cr33D
Gentleman!!
