Author Topic: Traction control light permanently on - MOT coming up  (Read 4455 times)
1337
« on: January 11, 2017, 06:04:13 pm »
Hello, my traction control light has come on permantly? Any ideas on a quick fix? MOT in 2 weeks. Recently had a front D/S tyre fitted? Thanks any help would be grateful!
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Traction control light permanently on - MOT coming up
« Reply #1 on: January 11, 2017, 06:11:56 pm »
Quick fix? How about fixing it properly? You need to get the fault diagnosed which means a code read at a minimum..... and go from there. If the light came on at the same as the tyre was fitted then it's possible the ABS sensor or wiring was damaged
« Reply #2 on: January 11, 2017, 06:52:22 pm »
Is it traction light or tyre pressure monitoring light?
Offline patpong_pete
« Reply #3 on: January 11, 2017, 11:12:00 pm »
is the ABS light on as well as traction must be abs ring or wire damage
« Reply #4 on: January 12, 2017, 11:22:57 am »
If it's the 'tyre' icon, you probably just need to press and hold the 'SET' button to reset the rotational circumference differences because of the new tyre (ABS ECU thinks you've got a flat).
If it is the 'skidding car' icon, that will need some investigation.  Need to get it scanned as already mentioned.
