Author Topic: Brake Bleeding Procedure  (Read 7637 times)
Offline monk180
« on: January 11, 2017, 07:27:52 pm »
Hi Folks,
After having the sensor in the pedal for the ESP fixed, the brake pedal is spongy, and if you press on it firmly for a period of time goes to the floor. Not a good thing if you are braking slowly from high speeds.
I hear that you have to use software to bleed the system by running the ABS pump.
What is this software, and the procedure?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: Brake Bleeding Procedure
« Reply #1 on: January 11, 2017, 08:16:11 pm »
Offline monk180
« Reply #2 on: January 11, 2017, 10:14:31 pm »
Thanks - yes the brakes to feel better after some ABS / ESP action.
Offline skard
  • -Receive: 245
« Reply #3 on: January 11, 2017, 10:56:30 pm »
See http://www.micksgarage.com/blog/project-gti-how-to-bleed-your-brakes/
Coincidentally, I totally flushed my Touran brake fluid today.
As usual, after running the ABS pump the colour was manky. When I bled the clutch it looked like old engine oil coming out.
