"cloudy" lenses can be polished using kits from 3M amongst others. Go easy as its plastic ![happy2 :happy2:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/happy2.gif)
I think he means the projector lenses - can only access these by splitting the lights.
Also, the xenons are glass. However, you're right that polishing can massively improve the plastic (non-xenon) units.
This is my nephews car. Process was as following:
- Admire the cloudiness.
- Tape off around the headlights
- Wet sand (I forget which grade I had) until cloudy effect gone
- Admire the new Matt finish. sh*t yourself and wonder if you've done the right thing
- With a DA polisher, polish with a firm/medium pad and compound, and then buff with a soft pad
- Remove excess polish (I use gtechniq panel wipe)
- Apply sealant
Before
![](https://uploads.tapatalk-cdn.com/20170112/d7f89b247f3ff87fb80928375725d2af.jpg)
Closeup before
![](https://uploads.tapatalk-cdn.com/20170112/5a5d61ab05b8b70f49669f9de07e6530.jpg)
After
![](https://uploads.tapatalk-cdn.com/20170112/db3035fa50eb7e9a7785a543368f4e3c.jpg)
Closeup
![](https://uploads.tapatalk-cdn.com/20170112/ba90be320f2fe026912c2ab604371583.jpg)
Much better!
