Author Topic: Seat Leon Cupra brake upgrade  (Read 2615 times)
Offline munster
« on: January 13, 2017, 11:38:44 pm »
I'm looking at Leon cupra brakes from a 2013 donor car. 340mm fronts and 310mm rears. Apart from the discs,pads,calipers and dust shields what more do I need.
Assuming I will need the matching caliper carrier brackets and brake lines or will the original brake lines fit?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Seat Leon Cupra brake upgrade
« Reply #1 on: January 14, 2017, 12:13:06 am »
Caliper brackets will be used from your current stock setup. Will need new brake lines.
You can also use r32 or audi s3 brakes. Same as cupra ones :)
Sent from my SM-G928F using Tapatalk
Offline munster
« Reply #2 on: January 14, 2017, 10:16:58 am »
Cheers mate, wasn't sure if carriers were different or not. Do you just need to order the S3 / Leon brake lines or are they special order to mate the systems together?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: January 14, 2017, 10:59:49 am »
The stock s3 ones will work
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: January 14, 2017, 12:09:46 pm »
Sorry i made a mistake in my other post , you will need the caliper brackets from s3 or r32 setup too
