Author Topic: Boost pipe map sensor  (Read 1752 times)
Offline Geomac901
« on: January 15, 2017, 06:21:36 pm »
Hi folks,
Could anyone tell me the wires for the map sensor on the boost pipe /intercooler charge pipe?
The sensor has been botched and crimped and the crimps have been plugged into the pins of the sensor and now I that I have a proper plug I'd like to do it properly: solder and heat shrink the new cables.
Looking around on the web I have managed to find that the 4 pin plug only uses 3 pins. Pin 2 is missed out.
1 is ground.
3 is 5 volts.
4 is the signal sensor.
What wires correspond to the correct pins? I have 3 wires: black, orange and pink/green.
Any help would be great.
George
Sent from my ONE E1003 using Tapatalk
55 plate mk5 GTi steel Grey.. Full leather with heated seats,  armrest with cd changer and flat bottomed steering wheel. Very standard :( 2.0 Tfsi Petrol.  That's all for now! :P
Offline SpudGTI
  • -Given: 18
Re: Boost pipe map sensor
« Reply #1 on: May 18, 2018, 06:30:43 pm »
Hi bud have you sorted this i have same problem and need to knkw what wire goes to what pin
Sent from my SM-G935F using Tapatalk
Offline SpudGTI
  • -Given: 18
« Reply #2 on: May 18, 2018, 06:50:55 pm »
Not sure if its rite but ive put
Black 1
Orange 3
Pink/green 4
Hope its rite but we will see once i get a code reader on it
