Author Topic: Question for manual owners  (Read 5871 times)
Offline holepunch
Re: Question for manual owners
« Reply #15 on: January 28, 2010, 03:31:07 pm »
On the subject of manual gearboxes - does any one else find it a little whiney in the lower gears, again particularly from cold?
Yes My 50k 2006 suffers from this.
Offline snapey
« Reply #16 on: January 28, 2010, 06:26:06 pm »
Just got in and had a feel around with the linkage on the actual gearbox and there's tonnes of play in the main bushes. I'll get on it at the weekend and see if it makes any difference.
Cheers for the info chaps, you've all been a big help.
If you have to ask why, you'll never understand.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #17 on: January 28, 2010, 06:49:34 pm »
there are some metal inserts you can get to replace them  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline snapey
« Reply #18 on: January 28, 2010, 06:52:17 pm »
OEM John?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #19 on: January 28, 2010, 07:03:00 pm »
afraid not.
but jonnyc has them
"Force fed engineering solid bushings - Shift cable support bracket"
http://forums.fourtitude.com/zerothread?id=4683767
http://store.forcefedengineering.com/SearchResults.asp?Cat=112
« Last Edit: January 28, 2010, 07:04:50 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #20 on: January 29, 2010, 08:59:02 am »
No problem with mine.
Offline gonegolfing
« Reply #21 on: January 29, 2010, 09:23:01 am »
Mines a bit notchy when cold!! but fine warm 07 24K..
Offline tonker3
« Reply #22 on: January 29, 2010, 01:40:12 pm »
Mine sometimes seems juddery when dropping into second gear at relatively slow speed, for instance turning at a junction. Has been like this since new 2 years ago. Hasn't really changed in nature. Rest of the time the Gbox is smooth through all the gears.
Offline v2brett
« Reply #23 on: January 29, 2010, 09:21:50 pm »
anyone got a part number and price for these bushes?  :happy2:
Still Here!
Offline WhiteGTI
  • F-A-S-T
« Reply #24 on: January 29, 2010, 09:25:35 pm »
Mine's a bit notchy from cold and can be a bit reluctant to go back into 1st unless at a complete stop but once warmed up it fine.
I find that theres a lot of gearbox whine from my car! Its been like that since new, and mostly happens in 1st/2nd gear at low speed.
As for being notchy...its never been notchy really, always smooth and precise since new.
2006 E46 BMW M3 - 343hp
Offline snapey
« Reply #25 on: January 29, 2010, 10:33:12 pm »
Those bushes that you listed aren't the ones that are shagged John, at the minute its the actual linkage ones which I think I'm going to replace with these little beauties:
http://www.42draftdesigns.com/categories/products/mk5bsh.html
If the entire assembly has to come off because their done as well I'll do them at the same time.
