Author Topic: Wheel fitment  (Read 7449 times)
Offline Rowley102
  • My Ride: 2009 VW MK6 Golf GTI
Wheel fitment
« on: January 26, 2017, 11:44:14 pm »
BBS SR 016 - 18x8J 5-112 ET45.
Who reckons these would fit my Mk6 Golf GTI?  My fitments 5X112 and current offset is 51 on my monzas
2009 Golf GTI 2.0, Tornado Red, Engine code: CCZB, Manual, RCD 510, Custom 2.5" Turbo back Sports Cat Exhaust System with 4" slash cut tips, Ram-Air Oversized Induction, 225/40/18 Goodyear Eagle F1 Asymmetric 3s, Monza Shadow Alloys, Ferrodo DS2500 pads, braided lines, Millers Nano-drive 5W-40
2009 Golf GTI 2.0, Tornado Red, Engine code: CCZB, Manual, RCD 510, Bluetooth, Heated leather seats, Cruise control, 225/40/18 Goodyear Eagle F1 Asymmetric 3s, Monza Shadow Alloys, Millers Nano-drive 5W-40
Offline Rowley102
Re: Wheel fitment
« Reply #1 on: January 27, 2017, 07:58:04 am »
Tyres that will be fitted are 225/40/18
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Wheel fitment
« Reply #2 on: January 27, 2017, 08:57:31 am »
Yes, they will fit spot on.
Offline Stig_gti
Re: Wheel fitment
« Reply #3 on: January 27, 2017, 09:13:22 am »
Yes will fit no problem I'm running the exact same wheel spec And  tyre spec on my mk6 gti with out any problems.
One issue I do have tho my car is on h&r springs and I get a little rubbing on the front from the wheel arch.
Seems to be the arch liner and screw which is common problem on these cars, simple fix remove the screw and move the tab out the way.
Offline bonelorry
  • -Given: 72
  • -Receive: 44
Re: Wheel fitment
« Reply #4 on: January 27, 2017, 03:28:45 pm »
I currently have Team Dynamics Pro Race 1.2's....
18 x 8J, 5 x 112, ET45.
Fit perfect  :happy2:
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Wheel fitment
« Reply #5 on: January 27, 2017, 04:54:05 pm »
Really? I'm 18x8 et44 225 40 18 and I'm nowhere near rubbing.
Arches are untouched, no screw mods.
« Last Edit: January 27, 2017, 05:27:39 pm by AJP »
Offline Stig_gti
Re: Wheel fitment
« Reply #6 on: January 27, 2017, 06:54:54 pm »
So why am I running I'm on h&r springs with et45 18x8inch 225 40 18 tyres.
Oz ultraleggeria wheels.
Is mk6 different to the mk5 wheel arch.
Offline Stig_gti
Re: Wheel fitment
« Reply #7 on: January 27, 2017, 07:01:43 pm »
Should also say it only rubs when I come down off a speed bump or hit a ditch.
That is also not driving fast.
Offline Rowley102
Re: Wheel fitment
« Reply #8 on: January 27, 2017, 07:24:49 pm »
I wouldn't be bothered about any slight rubbing when youve gone ever a speed bump ;)
Offline addictivev8
Re: Wheel fitment
« Reply #9 on: January 28, 2017, 08:41:53 am »
Stig I'm on H&R's with the exact same wheel and tyre spec as you and I get rubbing too on the rear if I have passengers.
I may end up going with the srs tech wings and have the rears flared too match as I want a slightly bigger tyre and a far more aggressive offset (in order for the wheels I want to clear the brakes I have).
« Last Edit: January 28, 2017, 08:44:06 am by addictivev8 »
Offline Stig_gti
Re: Wheel fitment
« Reply #10 on: January 28, 2017, 08:49:28 am »
The srs tech wings look great wasn't planning on going that far into body work.
I haven't noticed any rubbing on the rear only the front, which I'm guessing the screw mod will fix.
If I start to notice any rubbing on the rear I will either roll the arches or go wrc springs.
Offline bonelorry
  • -Given: 72
  • -Receive: 44
Re: Wheel fitment
« Reply #11 on: January 28, 2017, 09:47:46 am »
Mine doesn't rub but then I have not gone for really low Springs!
Offline addictivev8
Re: Wheel fitment
« Reply #12 on: January 28, 2017, 10:06:18 am »
Mine has the screw mod and the front is fine!
TBH I doubt I'll go that far especially as my wings are rust free so maybe just a solid roll all round. Either way that'll be a project for the summer.
Offline Stig_gti
Re: Wheel fitment
« Reply #13 on: January 28, 2017, 10:18:57 am »
Sounds like my plans aswell so far.
I will do the screw mod and see how it goes, if rear starts rubbing then I've got two options. :thinking:
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Wheel fitment
« Reply #14 on: January 28, 2017, 12:32:38 pm »
I'm also on H&R springs. Mine's a mk5, but a mk6 is pretty much the same thing suspension wise.
