Author Topic: Pcv delete or not?  (Read 10788 times)
Offline b7unr
Pcv delete or not?
« on: January 27, 2017, 09:37:10 pm »
Hi as previously mentioned I'm no mechanic but am interested in pcv delete, I'm not sure what it does or understand what is does, but does it make any difference to performance or will it help the engine.
Basically if it's beneficial I'll buy one?
Offline b7unr
Re: Pcv delete or not?
« Reply #1 on: January 29, 2017, 10:35:02 am »
Hi does anybody recommend a pcv delete ??
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #2 on: January 29, 2017, 05:25:18 pm »
Only on a highly tuned car.
I just run the OEM Factory Revision R, No problems at 320BHP  :happy2:
Offline b7unr
« Reply #3 on: January 29, 2017, 10:13:49 pm »
OK cool, mine is 331bhp 450nm so I guess I'll be OK with the R version.
Thank you
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: January 29, 2017, 11:23:09 pm »
Stick with OEM unless you want to go down the full PCV delete vent to atmosphere setup. Do not buy one of the half arsed attempts from the likes of Forge and so on. They cause more harm than good
Offline th3_f15t
  • -Receive: 183
« Reply #5 on: February 22, 2017, 11:14:36 am »
Got anything to back up that claim about Forge items? Run one of them myself and not had any issues so far but always interested to read up on things like this!
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: February 22, 2017, 01:26:53 pm »
Do you mean the multitude of posts both on this forum, Facebook and so on, complaining of burning oil/exhaust smoke after fitting? Specifically at idle and on over run etc. (Vacuum). It's caused by forcing both crank and cam gas pressure in to the intake pipe via the tiny recess in the back of the plate. The R-Tech kit only channels the cam area pressure through this route via a much larger recess in the plate, whilst the crank case pressure is vented elsewhere.
Offline th3_f15t
  • -Receive: 183
« Reply #7 on: February 22, 2017, 01:39:34 pm »
I knew the R-Tech kit was the only one people recommend, but not really studied the Forge unit in particular. Seen a lot of discussion about the fact most catch cans don't actually catch oil or much other than water. Not seen any evidence of smoke on my car since fitting it but shall certainly monitor things.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: February 22, 2017, 04:32:05 pm »
I have the Forge oil catch can PCV delete kit. I haven't noticed smoke so far. It catches a kind of mayonnaise-like liquid.
