Author Topic: Misfire 4th 5th 6th after remap  (Read 8520 times)
Offline Seanie
Re: Misfire 4th 5th 6th after remap
« Reply #15 on: January 29, 2017, 04:13:55 pm »
No it was an Irish company
Sent from my SM-N910F using Tapatalk
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=i33sjlargdae82ons72rldijjc&/topic,19740.0.html
« Reply #16 on: January 29, 2017, 04:16:15 pm »
Ohh ok.  280 is a very high figure for a K03 TFSI engine. Youd need a upgraded HPFP to get anywhere near that figure.
Offline Seanie
« Reply #17 on: January 29, 2017, 04:17:50 pm »
No you don't I have a standard hpfp
« Reply #18 on: January 29, 2017, 04:21:13 pm »
OK... well in that case it didnt make a true 280bhp then. The Dyno was generous.
Anyway... back to the misfire. Have you not spoken to the place who remapped it?
Offline Seanie
« Reply #19 on: January 29, 2017, 04:22:46 pm »
I have spoken to him and he recommended ignition coils
Offline Seanie
« Reply #20 on: January 29, 2017, 04:23:20 pm »
« Reply #21 on: January 29, 2017, 04:29:17 pm »
I wasnt doubting that the tuners dyno said 280.... I am simply trying to explain to you that unless you've got a HPFP, you wont be making 280bhp on a dyno that reads correctly. In reality its probably making nearer 270.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #22 on: January 29, 2017, 06:11:29 pm »
Just to play devil's advocate @rich83...
My car made 270 with just a full BCS (sport cat) and Pipercross panel down at Hinckley.
Could it have made 10bhp more at peak with a well-flowing intake like a Ramair? Probably. I honestly doubt my Pipercross panel gave much more than a stock filter would.
There's also something worth considering with Seanie's map. If boost is tempered a bit at mid revs, say around 3k, it gives the turbo (mapper) a chance of producing a little more boost at higher revs. Mine made 345lb/ft of torque at 3200rpm, but dropped off a cliff soon after. This map makes considerably less torque at around 3k, but then holds on to the torque much better than mine.
So, it's maybe fairer to say that this car could indeed be making enough torque at high enough revs to make 280bhp peak power, at the expense of that good old k03 punch at low-mid revs.
It's also just as likely that this dyno, or any dyno for that matter, isn't entirely accurate
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #23 on: January 29, 2017, 06:21:04 pm »
This is my graph. Where Seanie is making peak power - 5800rpm - he's at about 260lb/ft.
At 5800rpm my car produced something like 240lb/ft. A fair chunk less than Seanie's.
Offline Saintsteve
  • -Given: 17
« Reply #24 on: January 29, 2017, 06:46:36 pm »
Why not just hand the car back to the tuner and say fix it? :thinking: :doh:
Tornado Red Edition30 DSG Build Number 114
Atlantic Blue Mk7.5 GTE Advance
Follow Saintsteve330 on Instagram
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #25 on: January 29, 2017, 07:32:51 pm »
Because it isn't the tuner's responsibility to check or fix ignition/fuelling hardware.
Offline Seanie
« Reply #26 on: January 29, 2017, 08:35:30 pm »
@AJP That's was my opinion aswell, he has done his job and has been great with giving advice and help on what to do.
So thanks guys for your advice and I am going to go the route of changing coils first and then I will let ye know how things are going.
Appreciate your help
« Reply #27 on: January 29, 2017, 10:14:22 pm »
Dyno lottery.
Offline Seanie
« Reply #28 on: February 01, 2017, 08:56:16 pm »
Well guys just to update ye I have just put in the genuine red coils from Audi and what a difference they have made and I want to thanks all of ye for your advice and it was a top notch diagnosis
Offline The Red Warrior
« Reply #29 on: February 02, 2017, 10:00:31 am »
Thanks for the update!
It's all too often that threads just fizzle out after the problem is solved and no one becomes any the wiser from reading them.
Another win for the forum members  :star:
