Author Topic: Mk6 mirror switcheroo  (Read 570 times)
Offline Matt81
  • -Given: 47
« on: January 29, 2017, 12:47:02 pm »
Hi guys.
Those who've fitted the mark 6 switch....
Is your folding/heating controls backwards?  Icons are the same way around but function appears reversed.  I.e heated mirror folds them in.
Baffled.
Sent from my SM-G935F using Tapatalk
Offline PatchySan
  • -Receive: 59
  • Gracie!
Re: Mk6 mirror switcheroo
« Reply #1 on: January 29, 2017, 01:04:33 pm »
Mine is flipped too, was trying to remove the condensation while I was driving only to find out it folded in instead! :grin: I bought my switches overseas and given it's designed for LHD markets where they sit on the otherside I believe that it's not a fault of the switch.
I've got used to it in the end but if you're a perfectionist you need the UK (RHD) spec one from the dealer.
Offline Matt81
  • -Given: 47
« Reply #2 on: January 29, 2017, 01:18:38 pm »
Thought it might be that.  Had assumed as the icons were the same way id got the correct one.
Don't fancy paying dealer prices.
Offline Matt81
  • -Given: 47
« Reply #3 on: January 29, 2017, 09:23:28 pm »
Thinking about it.  If I know the wire out arrangement I could rewire it after the switch.
Hmmmm
