Author Topic: 225X40X18 or 255X35X18  (Read 6789 times)
Offline poko
Re: 225X40X18 or 255X35X18
« Reply #15 on: January 29, 2010, 12:50:34 pm »
it looks like too much of a job after looking at it today.
what do you think on 245X40X18 ?
will the extra height be a problem
Offline jonnyc
  • Herrooooo!
« Reply #16 on: January 29, 2010, 12:54:21 pm »
3 options if you want to stay with stock rotational diameter.. 225/40 255/35 or 285/30
I have ran 235/40 and that's ok, only a few mm but 245/40 would be daft..
« Reply #17 on: January 29, 2010, 04:30:02 pm »
Any use?
335 25/18, diameter diff: -1.96% , speedometer will read faster than actual.
  155 55/18, diameter diff: -1.49% , speedometer will read faster than actual.
  285 30/18, diameter diff: -1.41% , speedometer will read faster than actual.
  245 35/18, diameter diff: -1.33% , speedometer will read faster than actual.
  215 40/18, diameter diff: -1.26% , speedometer will read faster than actual.
  145 60/18, diameter diff: -0.94% , speedometer will read faster than actual.
  175 50/18, diameter diff: -0.78% , speedometer will read faster than actual.
  195 45/18, diameter diff: -0.71% , speedometer will read faster than actual.
  295 30/18, diameter diff: -0.47% , speedometer will read faster than actual.
  255 35/18, diameter diff: -0.24% , speedometer will read faster than actual.
225 40/18
  165 55/18, diameter diff: +0.24% , speedometer will read slower than actual.
  305 30/18, diameter diff: +0.47% , speedometer will read slower than actual.
  205 45/18, diameter diff: +0.71% , speedometer will read slower than actual.
  185 50/18, diameter diff: +0.78% , speedometer will read slower than actual.
  265 35/18, diameter diff: +0.86% , speedometer will read slower than actual.
  155 60/18, diameter diff: +0.94% , speedometer will read slower than actual.
  235 40/18, diameter diff: +1.26% , speedometer will read slower than actual.
  145 65/18, diameter diff: +1.33% , speedometer will read slower than actual.
  315 30/18, diameter diff: +1.41% , speedometer will read slower than actual.
  275 35/18, diameter diff: +1.96% , speedometer will read slower than actual.
  175 55/18, diameter diff: +1.96% , speedometer will read slower than actual.
Offline poko
« Reply #18 on: January 29, 2010, 05:12:50 pm »
335/25/18 it is  :laugh:
Thanks for the help
I will do the change approx in a month
Ill set up one wheel in 255 and if i cant sort it on the cupra revert to 225 in r888
