Author Topic: Revision G DV  (Read 1519 times)
Offline Trav Turbo
  • -Given: 18
Revision G DV
« on: January 31, 2017, 10:15:37 am »
When VW to order a DV (Dump Valve) gave him the part number I was given for Revision G. Parts guy says there is 2 types & saying Revision D is the latest for later Gti. Has he got this wrong?
Re: Revision G DV
« Reply #1 on: January 31, 2017, 10:26:45 am »
Rev G & D have both been available for ages.   Some dealers will just order the number you give them, and some are jobsworths and insist on following what it says on their screen.
Offline mikezs
Re: Revision G DV
« Reply #2 on: January 31, 2017, 11:50:18 am »
G is the type latest with the rubber diaphragm that is still prone to breaking, but people like it because it seals best.
The D is the plastic version that is fitted to newer cars that won't wear out.
Your choice!
G (left) and D (right)
Offline Trav Turbo
  • -Given: 18
Re: Revision G DV
« Reply #3 on: January 31, 2017, 12:55:02 pm »
Your choice!
Thanks. I ordered G
Sent from my SM-N910F using Tapatalk
Offline shoaybmakda
  • -Receive: 54
Re: Revision G DV
« Reply #4 on: January 31, 2017, 01:45:13 pm »
Revision D is also prone to boost leak
Offline Shamm
Re: Revision G DV
« Reply #5 on: January 31, 2017, 08:19:18 pm »
So is it better to get the gfb dv+  ?
Offline shoaybmakda
  • -Receive: 54
Re: Revision G DV
« Reply #6 on: January 31, 2017, 10:06:03 pm »
@Shamm yes - fit and forget part and no need to mess about once it's done.
