Author Topic: R32 Rear  (Read 6007 times)
Offline DPG
R32 Rear
« on: January 28, 2010, 04:36:21 pm »
Quick question for those that have done the R32 rear mod
Is it just the bottom part of the bumper that i would need? (the bit that is not sprayed on the GTI)
How much would you expect to pay on eBay or from a dealer?
Dan
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: R32 Rear
« Reply #1 on: January 28, 2010, 05:22:27 pm »
It's just the bottom bit you will need, yes.  You will also need to get the relectors and some fixing brackets... not sure how much they go for on eBay.
Got mine from VW for around £300, plus or minus £50.
Offline rjwojcik
Re: R32 Rear
« Reply #2 on: January 28, 2010, 08:21:29 pm »
Interesting, so you don't have to replace the whole bumper?  What exhaust did you use (I hear Millie do one).
  • MUBster DUBster
Re: R32 Rear
« Reply #3 on: January 28, 2010, 09:11:35 pm »
I personally got a milltek on based around the R32 bumper.
Check out the photos in my build thread if you need to see how it all looks.
Offline rjwojcik
Re: R32 Rear
« Reply #4 on: January 29, 2010, 09:17:58 am »
Re: R32 Rear
« Reply #5 on: January 29, 2010, 09:39:14 am »
The R32 part you need is what VW call the 'Rear Spoiler'. The part which attaches to it is called the 'Exhaust Trim'. I've got the part #'s filed away so shout if you need.
There are several aftermarket exhaust trims available to suit various exhaust pipe configurations and the VW spoiler has cut-outs to accommodate them all too.
Hope This Helps
Offline Sie
Re: R32 Rear
« Reply #6 on: January 29, 2010, 06:21:25 pm »
Part numbers would be great please??
Sie
Fettled Laser Blue '05 GTi 5dr
Offline Pablos007
Re: R32 Rear
« Reply #7 on: January 30, 2010, 11:33:52 am »
+1  :happy2:
Re: R32 Rear
« Reply #8 on: January 30, 2010, 12:08:15 pm »
Ooops! I got busy and forgot.
Mk5 R32 Spoiler: 1K6 807 433 C GRU
Mk5 R32 Exhaust Trim: 1K6 807 568 9B9
I don't know the reflector part #'s
HTH  :smiley:
Offline Pablos007
Re: R32 Rear
« Reply #9 on: January 30, 2010, 12:32:24 pm »
Thanks  :happy2:
Had a root around the web and found these as well, I believe they're correct part no's:
  • LH Reflector 1K6-945-105-A
  • RH Reflector 1K6-945-106-A
  • Tow Hook Cover 1K6-807-441-E-9B9
  • Foam Absorber 1K6-807-251-A
  • LH Support 1K6-807-739
  • RH Support 1K6-807-740
Re: R32 Rear
« Reply #10 on: January 30, 2010, 12:43:40 pm »
Thanks  :happy2:
....For what it's worth, the only parts I needed from your list, Pablo, were the reflectors. But perhaps my bodyshop had it all covered.
Btw, Spoiler and Trim come primed.
Offline Pablos007
Re: R32 Rear
« Reply #11 on: January 30, 2010, 12:56:26 pm »
Cheers for the tip, I'm assuming some of the GTI bits should be re-usable.  Will let you know when I located a good bumper and get it all fitted.
Offline DPG
Re: R32 Rear
« Reply #12 on: January 30, 2010, 01:00:41 pm »
What colour car have you got?
Offline Pablos007
Re: R32 Rear
« Reply #13 on: January 30, 2010, 01:37:57 pm »
2006 GTI in metallic black (paint code - LC9Z)
Hoping to find on the right colour to save hassle.  I've got an Ebay watch on the complete lower section though it starts at £200.
Offline DPG
Re: R32 Rear
« Reply #14 on: January 30, 2010, 02:25:48 pm »
Cool, i was going to send you the link to it as i was watching it too.
Not in a position to buy this month and i've just paid for the RNS510
Dan
