Author Topic: Advice yellow oil light stuck on  (Read 11047 times)
Offline eoin0706
« on: February 07, 2017, 08:23:01 am »
Hi guys just looking for some advice my oil can light came on yeterday evening when i started the car,topped it up to the correct level but the yellow oil light will not turn off on the dash,is this a common occurance and is it a tricky fix.
Eoin
Ps its an 06 mk5 gti
Offline mikezs
Re: Advice yellow oil light stuck on
« Reply #1 on: February 07, 2017, 09:24:50 am »
If it was low and needed topping up and the light now won't go off, there's sometimes a problem with the bonnet catch sensor. Open the bonnet and see if the light for an open door comes on on the dash to check it's working. There's also an oil level sensor that sometimes can fail, but it's less common.
Bonnet catch sensor can just be cleaned carefully
Offline eoin0706
« Reply #2 on: February 07, 2017, 10:50:33 am »
Thanks for the advice i will try those items you have pointed out and see how i get on ie cleaning the bonnet catch and checking the dash to see if its indicating the bonnet is open
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: February 07, 2017, 10:54:00 am »
The issue is when the bonnet sensor doesn't recognise that the bonnet has been opened and then closed i.e. so the oil has been checked and topped up.
Offline eoin0706
« Reply #4 on: February 07, 2017, 11:04:11 am »
Hi Dan_fr thanks for the reply yes i topped the car up yesterday so all is good there i will look at it afterwork today hopefully its not much of an issue
  • -Receive: 692
« Reply #5 on: February 07, 2017, 02:43:59 pm »
I can't decide if that's clever, or daft, since the sump has a sensor in it!  Or is it just an oil 'condition' sensor, rather than level?
Offline eoin0706
« Reply #6 on: February 07, 2017, 04:16:04 pm »
So my dash board reading is not telling me the bonnet is open so it must be a faulty sensor there by that process of elimination,does anybody no the part no. and approx price for this sensor?
Offline strongbow
« Reply #7 on: February 07, 2017, 07:34:19 pm »
part no; 1k1823509e look for lock with sensor attached, found mine on ebay genuine vw part about £50.
on the how to do guides , look for hood lock replacement under the body section, nice easy job,should do the trick.
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #8 on: February 07, 2017, 07:39:29 pm »
1K1 823 509 E.  Tps price is £46.63 I'm not sure if that's before or after vat on my catalogue
Offline eoin0706
« Reply #9 on: February 07, 2017, 09:41:48 pm »
Thanks for the part no. Guys
Offline Chris_R
« Reply #10 on: February 07, 2017, 11:18:44 pm »
May also just need cleaning, that are is often covered in old grease which dirt sticks to. Worth giving it a quick spray with WD40 to strip out the old grease and dirt first before getting the parts replaced.
Offline eoin0706
« Reply #11 on: February 08, 2017, 08:14:54 am »
Thanks Chris R :happy2:
Offline eoin0706
« Reply #12 on: February 12, 2017, 08:30:00 pm »
Started the car this morning and oil light has gone now,im stumped but atleast its gone for the moment..
