Author Topic: VW Racing air intake  (Read 2493 times)
Offline Lewo
« on: February 09, 2017, 10:15:17 pm »
I had a rush of blood the other day and bought one off another forum as you don't see them up for sale second hand that often.
I was thinking about getting the car modded from stage 1, and buy the parts needed as and when they come along.
Having calmed down and thought it through properly it's going to cost a lot especially if I get a K04 turbo as well, 18" wheels & better brakes..... :thinking:
So pretty sure I'll put it up for sale on here. The one I bought is this one for the K04, just wondered if it can be used with a K03 as well if it's possible to blank off the ali pipe? https://vwpartsinternational.com/wp-content/uploads/2014/12/Golf-MK5-GTI-Edition-30-Pirelli-Edition-VW-Racing-Intake-System.jpg
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: VW Racing air intake
« Reply #1 on: February 09, 2017, 10:45:41 pm »
Pretty sure it can be used with ko3, like you said you just need to blank off
« Reply #2 on: February 10, 2017, 09:34:22 am »
How much are you thinking of putting it up for?
The VWR is the best intake I've seen for these engines by a country mile, apart from it has no flex section to absorb engine movement, which is such an obvious over sight for the huge sum they charge for it.
Offline golfmck1980
« Reply #3 on: February 10, 2017, 10:14:50 am »
Yeah one of my local tuners is a stockist for them and swears by them but they are crazy money new
Edition 30 num 859
« Reply #4 on: February 10, 2017, 10:51:57 am »
You can just tell it was designed by someone who knows the engine.  I.e. no massive drain pipes with a randomly sized plant pot filter shoved on the end.
You can have the biggest kitchen sink in the world, but all that water still has to flow through the same size plug hole.
Offline d0mokun
  • Merovingian Ninja
« Reply #5 on: February 10, 2017, 11:09:22 am »
I have the VWR intake on my GTi and it's a heck of a lot louder than the stock GTi and Ed30's I've had previously. It also has a tendency to whine under heavy throttle, though I think that's to do with the way the intake is mounted in my particular setup.
Totally not on topic but just a few notes regardless!
Dan.
My current cars are:
08 S5 4.2 ¦ 79 Trabant P601L
Artist and car lover.
« Reply #6 on: February 10, 2017, 11:35:29 am »
Dan.
It may be a bit OT but imo, this kind of real world experience & knowledge sharing is invaluable when it comes to parting with nearly £500 for an intake  :happy2:
Offline Vintyd
« Reply #7 on: February 10, 2017, 01:27:53 pm »
I believe the Revo is best for power when your maxing out the K04 if your not then they are all very similar just different sound  :smiley:
Offline Lewo
« Reply #8 on: February 10, 2017, 02:15:03 pm »
Anyone know if they make a blank to put in the pipe so you can use with k03?
« Reply #9 on: February 10, 2017, 02:31:37 pm »
VWR used these fittings to make the inlet for the KO4 dump hose - http://www.revotec.com/acatalog/Self-Sealing-Fittings-with-Push-On-Tail.html
You could try emailing them to see if they do a blank off?
Offline v4rley
  • -Receive: 104
« Reply #10 on: February 10, 2017, 04:23:59 pm »
Just need a 25mm blanking bing from eBay. Couple of quid
