Author Topic: Xenon headlamp..  (Read 2119 times)
Offline leemk5
Xenon headlamp..
« on: February 14, 2017, 06:38:07 pm »
I recently purchased my MK5 GTI which has factory xenons, I noticed the passenger beam was way to high but couldn't get it down far enough with the adjuster, I took the cover off the back of the headlight and found that the xenon bulb and mount/lens are swinging up and down, really loose, like it has come off of its bottom mount, or maybe broken! Is this common? Can it be fixed?
Thanks.
Re: Xenon headlamp..
« Reply #1 on: February 14, 2017, 09:58:08 pm »
You can get a fixing kit for the light but sounds like it's come of the adjuster
Offline leemk5
« Reply #2 on: February 14, 2017, 10:41:18 pm »
And if it's come off the adjuster is that a simple fix?
« Reply #3 on: February 15, 2017, 01:01:27 am »
Can just clip back into place
Offline leemk5
« Reply #4 on: February 15, 2017, 07:30:35 am »
Thanks a lot I'll try it later on
Offline leemk5
« Reply #5 on: February 18, 2017, 04:35:03 pm »
Had a look today and you were right, it had come off the adjuster and clipped back on! Happy days! Thanks for your help.
« Reply #6 on: February 18, 2017, 04:43:15 pm »
Just check on the suspension arms the head light levellers are OK
Glad it's sorted thou :happy2:
Offline leemk5
« Reply #7 on: February 18, 2017, 04:58:59 pm »
Will do, are they prone to issues then?
