Author Topic: Central locking issue..  (Read 1773 times)
Offline leemk5
« on: February 18, 2017, 04:33:42 pm »
The drivers door lock on my GTI does not lock/unlock with central locking, the passenger door, boot etc locks/unlocks fine and indicators flash etc, it's just the drivers door that's at fault. It locks and unlocks fine using the manual lock barrel. I'm guessing I just need a new door lock module but just wondered if anyone can confirm that this Is the problem before before I buy a new one?
Offline Butler
Re: Central locking issue..
« Reply #1 on: February 18, 2017, 04:38:30 pm »
Check the wiring from the door to the car, they are prone to break..... same thing has just happened to mine and the wire has broken
Offline leemk5
« Reply #2 on: February 18, 2017, 04:56:38 pm »
Do you check in that gaiter between the body and the door, or do I need to take the door trim panel off?
Offline Butler
« Reply #3 on: February 18, 2017, 04:57:30 pm »
Yeah pull the gaitor back
Offline leemk5
« Reply #4 on: February 18, 2017, 05:42:25 pm »
Just looked couldn't see any broken wires.. maybe just the lock module failed
