Author Topic: Long coding for ch steering module.  (Read 40953 times)
MPS
« on: February 20, 2017, 08:00:41 am »
Like a twonk I didn't note down the long coding on my old steering module and now I'm having difficulty resetting the heavy steering. I've tried the turning the wheel trick but it doesn't work. Can someone with a manual gti and ch module scan and give me their long coding string please?
Re: Long coding for ch steering module.
« Reply #1 on: February 20, 2017, 08:01:36 am »
Have you just turned the wheel lock to lock or followed the adaptation process?
MPS
« Reply #2 on: February 20, 2017, 08:21:31 am »
Not followed the adaptation process.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: February 20, 2017, 08:57:51 am »
It will be the adaption process I'd say, PITA, it took me 3 times before it sorted. If you moved the slip ring then you need to re adapt
MPS
« Reply #4 on: February 20, 2017, 08:59:24 am »
I'm getting no feedback from the steering angle sensor in the measuring block.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: February 20, 2017, 09:06:41 am »
U need to login to the module using code 40168 and then do basic settings on 60,63 and 66. Login each time before doing basic settings. And then go for a drive and then do the full lock left, right and Straighten steering.
Sent from my SM-G928F using Tapatalk
MPS
« Reply #6 on: February 20, 2017, 09:12:19 am »
Thanks for all your help guys, I really appreciate it. I'll let you know how it goes.
MPS
« Reply #7 on: February 20, 2017, 09:24:32 am »
It's the long coding for the mk60 esp/abs unit I need as well...  :doh:
MPS
« Reply #8 on: February 20, 2017, 09:47:17 am »
I do have an autoscan of the old steering module but that doesn't include the long coding for the abs does it?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: February 20, 2017, 09:53:45 am »
you dont really need the long coding from anything, just use VCDS to log in to the module and apply basic settings on the 3 channels I mentioned earlier. :)
MPS
« Reply #10 on: February 20, 2017, 10:50:27 am »
Is that in 16-steering wheel or 44-steering assist? When I try security code 40168 in 16 it says Controller refused the key, error 35: invalid key
MPS
« Reply #11 on: February 20, 2017, 11:10:36 am »
I've got a power steering fault code as well.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: February 20, 2017, 11:43:20 am »
u need to do it on abs brakes module
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #13 on: February 20, 2017, 05:32:48 pm »
For steering assist basic settings (done via abs) to work, there needs to be no errors in your 03 - abs module.
If there are errors in abs, the basic settings on steering assist will appear to be accepted but basic settings will not stick and warning lights on dash will remain.
Jas
VCDS (Preston, Lancashire)
MPS
« Reply #14 on: February 20, 2017, 06:41:21 pm »
The power steering fault is incorrect settings or something. The horn doesn't work either?
My intention was swapping over from an AQ module to a CH as the cruise control doesn't work with AQ [I only found this out after I bought it].
I originally swapped over from my midline [factory fitted] swcm so I could make use of the mfsw buttons I bought. I'm very tempted to say sod it to the idea of mfsw and go back to my midline swcm - at least the cruise control was working with that.
I didn't save the scan at the time but from memory I think it was this code:
01309 - Power Steering Control Module (J500)
01309 - Power Steering Control Module (J500): Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
When found in Brake Electronics (MK60)
Incorrect Steering Aid Characteristic Setting
Incorrect Steering Aid Warning Lamp Setting
Driver Steering Recommendation (DSR) in activated in Brake Electronics but not in the Steering Aid Control Module or vice versa.
Possible Solutions
Check Brake Electronics Coding
Check Steering Aid Characteristic Setting
Check Steering Aid Warning Lamp Setting
Check Driver Steering Recommendation (DSR) Setting
Which is the correct setting for the DSR and where do I find it in the swcm?
Bloody minefield!! and I've collected 3 modules now!!!  :sad1:
« Last Edit: February 20, 2017, 07:04:01 pm by MPS »
