Author Topic: Long coding for ch steering module.  (Read 25136 times)
Offline Newbieintown
Re: Long coding for ch steering module.
« Reply #15 on: February 20, 2017, 08:15:41 pm »
I had the same issue the other week @RetroRaz helped me out big time... I ended up with an abs test mode fault.... driving at 13mph and turning steering wheel between 90-180 was a PITA.... 5am Tesco empty car park did the trick.
200bhp
Tornado Red
2006
MPS
« Reply #16 on: February 21, 2017, 11:06:26 pm »
Right, got a bit further,
Managed to get the steering to lighten up, still got fault codes in the abs module however, as follows:
                Address 03: ABS Brakes       Labels: 1K0-907-379-MK60-F.lbl
Control Module Part Number: 1K0 907 379 Q    HW: 1K0 907 379 Q
  Component and/or Version: ESP FRONT MK60      0102
           Software Coding: 0004738
            Work Shop Code: WSC 01279 785 00200
3 Faults Found:
01486 - System Function Test Activated
        000 -  -
00778 - Steering Angle Sensor (G85)
        005 - No or Incorrect Basic Setting / Adaptation
01309 - Power Steering Control Module (J500)
        008 - Implausible Signal
The ABS, ESP and TPMS lights are also lit up.
Is it safe to drive as it is?  :scared:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: February 22, 2017, 12:40:21 am »
I think you have the same error code as mine and it needs a dealer reset.
My steering works fine with no dash mil lights.
MPS
« Reply #18 on: February 22, 2017, 01:03:19 am »
can't understand why it will of need a dealer reset, been through the swcm swap process several times before and it's always been fine.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #19 on: February 22, 2017, 06:44:16 am »
        000 -  -
This is ok, once all other errors are sorted, we can deal with this one by the completing the test. Don't worry about it for now...
Quote
This one is due to steering angle and also steering limit stop basic settings needed. Details on Ross tech for the mk60 abs.
However, I don't think you will be able to clear it while you have the 01309 error.
Quote
This will be the cause of your problems.
I would remove and refit and check that all connections are definitely in place.
Also, is the steering module coded in 44 steering assist? If not, this might be cause of your problems.
If your horn doesn't work and steering wheel buttons do not light up, either there is a connection problem or a coding issue.
Other option is to disconnect battery for 20mins and try again .
Quote
It's ok to drive but be aware, your power steering may not function and braking may not be as good, abs may kick in when breaking at traffic lights, junctions etc
Jas
« Last Edit: February 22, 2017, 06:54:32 am by jason_rmh »
VCDS (Preston, Lancashire)
Offline The Red Warrior
« Reply #20 on: February 22, 2017, 06:59:43 am »
3 Faults Found:
        000 -  -
Push and hold both your ABS/ESP and TPMS buttons together. Hold them down for about 5 seconds. You should hear a 'bong' sound and the lights will go out.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #21 on: February 22, 2017, 07:32:50 am »
On steering wheel module coding there are options for the LIN  version as this module supports both v1 and  v2.
If you have the wrong coding, it could cause a communication issue.
MPS
« Reply #22 on: February 22, 2017, 12:06:55 pm »
Jas
Thanks again for your help
See this is the thing, the horn and the buttons aren't working, but the buttons do light up.
Matt
« Reply #23 on: February 22, 2017, 05:37:45 pm »
In the past I had loss of button function and loss of horn and it was faulty buttons
MPS
« Reply #24 on: February 22, 2017, 06:25:58 pm »
I wonder if its because I'm trying to use the old type [pre 2005.5] buttons with a newish generation [CH] steering wheel control module?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #25 on: February 24, 2017, 12:12:57 am »
Before you start worrying about the buttons, lets check a few things.
Ive been out to my car and got a few screen shots for you, a few things to try to narrow this down:
First, goto module 16 - Steering.
Measuring blocks. Check group 6.
This should confirm if there is communication with the module:
Next, check group 4.
Turn the steering wheel while monitoring group 4.
You will probably find that the steering angle DOES NOT change wheel you turn the wheel.
It should, but isnt due to the issue we are trying to solve.
Now goto basic settings in module 44 - Steering Assist.
Check group 7.
Here you should have 'Basic Setting' and 'Init'.
This should say 'OK' and 'Steering Ang Init' which means basic settings are ok and the G85 is initialised.
Yours will most likely say 'NOT OK' and 'Not Init'
Now, I suspect coding may be part of the problem.
Still in module 16 - Steering, check the coding:
Steering module supports old and new communication (LIN) versions.
This is why the CH module is popular as it supports both Mk5 and Mk6 MFSW.
Hover over the coding box and the bubble will appear, giving you the options:
Pay attention to the 5th digit (0xxx?xx: Multi-Function Steering Wheel):
This is where you tell the car which communication the module is to use:
options 1 to 4 = LIN 1.3 (If you are fitting a Mk5 MFSW)
options 5 to 8 = LIN 2.0 (If you are fitting a Mk6 MFSW)
Quote
0 = Multi-Function Steering Wheel not installed
1 or 5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
2 or 6 = Multi-Function Steering Wheel with Tiptronic and no Push-To-Talk (PTT) installed
3 or 7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
4 or 8 = Multi-Function Steering Wheel with Tiptronic and with Push-To-Talk (PTT) installed
For example, if you are fitting a Mk5 MFSW, with manual gear box ando do not have PTT (voice control), select 1.
My coding is '0000532'.
I have Mk6 MFSW, Manual, Cruise control, button on wiper stalk, No PTT.
So, take a note of your existing coding and check it is correct.
If not update it and see if it sorts out the communication issue.
Report back and we can go from there.
Jas
« Last Edit: February 24, 2017, 08:48:31 am by jason_rmh »
MPS
« Reply #26 on: February 24, 2017, 08:42:24 am »
Jas, you're a star, what's your PayPal Addy, have a few pints on me.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #27 on: February 24, 2017, 08:43:16 am »
Has it worked? Was it coding? :)
MPS
« Reply #28 on: February 24, 2017, 08:49:38 am »
No haven't tried it yet, just appreciate the lengths you're going to to help a stranger. I'll let you know.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #29 on: February 24, 2017, 08:51:46 am »
Ok, I was about to 'air punch' then.... I'll save it ;)
Keep us posted.
I had an issue with mine last week so know how frustrating it is trying to decipher what VCDS is trying to tell you.
Jas
