Author Topic: Long coding for ch steering module.  (Read 25143 times)
MPS
Re: Long coding for ch steering module.
« Reply #45 on: March 01, 2017, 06:07:32 pm »
I've cleared the J500 code!! It appears to have been caused by "driver steering recommendation" being turned off in module 44-Steering Assist adaptation channels  :happy2:
Also, something else I can't get my head around, in 03-ABS Brakes adaptation, channel 1 is set to Tire Pressure - 16 inch? There are 3 values you can select, 0 - 15 inch, 1 - 16 inch and 2 - 16 inch? Confusing and I'm guessing it has nothing to do with 18" wheels?
Also channel 9 is set to 'brake assist - center', the other possible settings are small and 2 large?
Matt
Offline Kai96
« Reply #46 on: March 01, 2017, 06:44:38 pm »
I'm all good now guys thanks for the help ! :happy2:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #47 on: March 01, 2017, 06:47:54 pm »
Good work both.
@r5gtt does this help you out?
« Last Edit: March 01, 2017, 07:30:25 pm by jason_rmh »
VCDS (Preston, Lancashire)
MPS
« Reply #48 on: March 01, 2017, 07:28:21 pm »
Good work both.
@R5gtt does this help you out?
Any ideas about those tire pressure settings @jason_rmh?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #49 on: March 01, 2017, 08:08:58 pm »
Good work both.
havent had the chance to try it yet mate @jason_rmh but will update this post as soon as I do thanks  :drinking:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #50 on: March 01, 2017, 08:17:34 pm »
I think no 2 may be a typo in the label file and is probably for 18".
I'll check mine and let you know
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #51 on: March 01, 2017, 10:21:47 pm »
you cannot change this as I've just tried
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #52 on: March 02, 2017, 12:15:51 am »
I've found the fault code doesn't delete but not sure why apart from replacing the steering rack.
Steering wheel is showing 0
ABS is the only thing showing weird readings
I haven't checked the fuses but will do that on my next outing to the car if that makes a difference
@jason_rmh
« Last Edit: March 02, 2017, 12:24:36 am by r5gtt »
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #53 on: March 02, 2017, 05:21:29 am »
Your J500 fault is slightly different. Check module 19 measuring blocks as mentioned earlier, that will confirm communication status of j500 with the can gateway.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #54 on: March 02, 2017, 03:56:40 pm »
hi, didn't you say module 16 earlier in the post and if so it's all fine and gives the software versions too @jason_rmh
« Last Edit: March 02, 2017, 04:00:07 pm by r5gtt »
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #55 on: March 02, 2017, 04:29:06 pm »
I said module 19, can gateway...
Goto module 19-CAN Gateway, Measuring Blocks > Group - 152
Field 2 should display the CAN-Bus status of the J500-Power Steering Control Module.
You should see a 1.
If you see a 0 then there is a communication issue between the CAN-Bus and the J500, which may indicate a broken wire.
Then, check fuses.
Engine bay, Fuse 3 (110-amp) (terminal 30)].
And there is a black wire from fuse 3 to J500, check that for breaks if you can.
Check driver's side fuse box, fuse 15 also, this gives ignition power to j500
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #56 on: March 02, 2017, 06:41:11 pm »
You should see a 1.
Then, check fuses.
oh rightio thanks I did check that but remembering getting an error but will double check that and also check the fuses this weekend to make sure non have blown. Thanks
MPS
« Reply #57 on: March 13, 2017, 10:09:36 pm »
Well oops. It appears my messing has caused a problem with the horn - it only works when pressed on the left hand side! I've unclipped the airbag again to have a look if I've caught any wires putting it back and it looks like I've pinched one of the single wires with a spade connector on the end. Are these ground wires?
Any ideas @jason_rmh ?
« Last Edit: March 14, 2017, 05:42:16 pm by MPS »
Offline NitrousOxide
I just swapped a 12-button MK6 Golf steering wheel in place of my 8-button MK5 Golf steering wheel. The swap went well, and all 12 buttons work. My issue is that the horn button does not work. I had swapped over the steering wheel control module from the stock ***AQ model to the ***CD model as it supports lin 1.3 and 2.0. I also replaced my old revision-C clock-spring with a new one as I wanted to ensure I had no wiring issues due to a previous airbag related fault in my old steering wheel (which appears to have now gone). I didn't make any coding changes to the new steering wheel control module, as I noticed a new fault in some modules about not being able to see the steering angle sensor (although the steering assistance "feels" fine). I had disconnected the main battery during the swap since I was replacing the driver's airbag.
Here is the AUTOSCAN after the swap with the new steering wheel and second-hand control module with airbag (however horn does not work).
Code: [Select]
Friday,27,March,2020,15:22:39:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
Data version: 20200210 DS308.0
www.Ross-Tech.com
Dealer/Shop Name: Matthew Taylor
Workshop Code: 123 12345 012345
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W111078   Mileage: 191360km-118905miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0020
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070160
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EE746-8060
No fault code found.
Readiness: 0110 0001
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 05108020    Serial number: 00001009061622
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 1C192DFCDF37EFAF59-8048
1 Fault Found:
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:27
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 12345 123 12345
   VCID: 73CB2640122900D7A8-8026
2 Faults Found:
00778 - Steering Angle Sensor (G85)
            000 - -
            004 - No Signal/Communication
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000014002
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 0021798C9B9F2B4FA5-8054
1 Fault Found:
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2020.03.27
                    Time: 00:07:28
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 01000007456322
   Coding: F78F8B270004800047140A001400008000191C075C00010D000000000000
   Shop #: WSC 12345 111 45725
   VCID: 71C72C48683532C75A-8024
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 300807 021  0501
   Coding: 00039861
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 12345
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86A78E-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
4 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            001 - Upper Limit Exceeded - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - MIL ON
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001632
   Shop #: WSC 01357 011 00200
   VCID: 76CD1F54015B15FF8F-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H06 0010
   Coding: 00000131
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Serial number: 00000000000000
   Coding: 170C01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 3851D16C83CFA38F5D-806C
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 030312F2002329
   Coding: 350001
   VCID: 3A55CB64B5C3B19FAB-806E
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:38
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0617
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF53B248DE3C11F1B-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 120B
   Coding: 0000560
   VCID: 3851D16C4BCFA38F5D-806C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 00028 028 00001
   VCID: 3753D25046D1ACF754-8062
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:38
             Freeze Frame:
                    Battery Volts: 13.6 V
                        DU
                    Temperature: 40.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 98900A085103007F42000F0FF0CA5A0610BC40
   VCID: 032B768042893057B8-8056
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            000 - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:39
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000564
   VCID: 3957D46870C5BA87A2-806C
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 74C9255C172707EFB1-8020
1 Fault Found:
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 00000401000005
   VCID: 63EB560062C99057D8-8036
4 Faults Found:
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:42
02633 - Antenna for Satellite Tuner
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:42
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:07:42
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 191365 km
                    Time Indication: 0
                    Date: 2014.08.18
                    Time: 00:10:51
End-------------------------(Elapsed Time: 01:24)--------------------------
Here is the AUTOSCAN prior to the swap with the horn working on my 8-button steering wheel, but original clock-spring and steering wheel control module
Code: [Select]
Friday,07,February,2020,06:36:12:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 190190km-118178miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
   VCID: 354FD8585CDD5EE744-8060
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:28:14
             Freeze Frame:
                    RPM: 823 /min
                    Load: 28.2 %
                    Speed: 0.0 km/h
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
Readiness: 0110 0101
   Coding: 0000020
   VCID: 1C192DFCDF37EFAF5B-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7AA-8026
7 Faults Found:
00474 - Control Module for Immobilizer
            004 - No Signal/Communication - Intermittent
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
01044 - Control Module Incorrectly Coded
            008 - Implausible Signal - Intermittent
01317 - Control Module in Instrument Cluster (J285)
01435 - Brake Pressure Sensor 1 (G201)
            005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
   Revision: 00001004
   Coding: 0000014002
   VCID: 0021798C9B9F2B4FA7-8054
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 243
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:07
   Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
   VCID: 71C72C48683532C758-8024
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
1 Fault Found:
01502 - Bulb for Rear Fog; Left (L46)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0013121
   VCID: 3D5FC07864ED86A78C-8068
5 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012122
   VCID: 01277C8858952247A8-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
   Coding: 170C01
   VCID: 3851D16C83CFA38F5F-806C
   Coding: 350001
   VCID: 3A55CB64B5C3B19FA9-806E
1 Fault Found:
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 27
                    Mileage: 190187 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:50:41
   Coding: 000000
   VCID: 6AF53B248DE3C11F19-803E
   Coding: 0000564
   Shop #: WSC 11111 111 45799
   VCID: 3851D16C4BCFA38F5F-806C
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
   Revision: 00H22000
   VCID: 3753D25046D1ACF756-8062
1 Fault Found:
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:28:19
             Freeze Frame:
                        DU
                    Temperature: 44.0°C
                    Count: 3
                    Count: 1
                        SteerAng n.Init
   Coding: 98900A085103007F42040F0FF00A5A0690BC00
   VCID: 032B768042893057BA-8056
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:28:19
   Coding: 0000564
   VCID: 3957D46870C5BA87A0-806C
   Coding: 0000003
   VCID: 74C9255C172707EFB3-8020
   Coding: 01000401000005
   VCID: 63EB560062C99057DA-8036
3 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:28:21
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 190182 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:28:21
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 190185 km
                    Time Indication: 0
                    Date: 2020.02.07
                    Time: 04:45:08
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 01:29)--------------------------
Can someone please suggest suitable coding for me, as I forgot to look at the configuration from my previous steering wheel configuration information before I pulled the module from the vehicle.
