Author Topic: Drivers door open alert, when door is closed.  (Read 2609 times)
Offline monk180
« on: February 21, 2017, 09:06:28 pm »
Hi,
Where is the sensor for decding if the door is closed, the alert comes on when the door is shut.
I can see no push sensor anywhere on the door frame, so I assume it must be in the lock.
Maybe spray the lock with WD 40?
Offline Chris_R
Re: Drivers door open alert, when door is closed.
« Reply #1 on: February 21, 2017, 09:14:42 pm »
Yeah its on the lock. Two switches in there one triggers if the door is locked or unlocked, the other if it is open or closed. You will be lucky to get the wd in there to get at the switch.
Have a look at this to see how it works
Offline monk180
« Reply #2 on: February 22, 2017, 09:51:14 am »
OK
Thanks for the reply! I will probably just suffer it till it gets very bad.
