Author Topic: Upgrading MFD2 to RNS-510  (Read 16480 times)
Offline cmdrfire
    • Commander Fire - my blog
Re: Upgrading MFD2 to RNS-510
« Reply #15 on: January 06, 2009, 11:58:59 am »
I'm after the Fiscon unit too... the OEM unit that Stu can supply is nice, but I like the extra functionality the Fiscon Basic Plus (new name for Pro IIRC) offers in the MFD.
« Reply #16 on: January 06, 2009, 01:39:54 pm »
ah thanks for that.
Do you know any details about the MRI ipod connection?
i have an armrest with factory fitted ipod connect. sods law says ill need to buy a new control module? i want the track names on the screen etc.
i guess it cant be done with my existing connection?
Offline 182_blue
  • -Receive: 54
« Reply #17 on: January 06, 2009, 02:25:17 pm »
good good, ive just bought a mk5 mfsw and i think im going to have to change a few major bits on the car. ive not got highline so i need some new clocks too.
looking to get the fiscon pro bluetooth system, even tho it costs a fortune!
and id love a reversin camera, but i dont know where to mount it flush
here  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #18 on: January 06, 2009, 02:34:59 pm »
^^^ Seeing the one on the Mk6 last night on 5th Gear got me thinking about this mod again  :wink:
Offline cmdrfire
« Reply #19 on: January 06, 2009, 02:47:18 pm »
ah thanks for that.
It's the MDI connection but IIRC you can't use the MDI connection and the FISCON Basic-Plus, you have to use MDI and Skoda bluetooth (but someone might have sorted this out already).
If you have CAN-gateway version "L" or newer you should be alright. Current revision is "S" and costs around £100 from your dealer.
I don't really need the reversing camera for my Golf but I do like the look of getting the OCR and Climatronic displayed on it.
« Reply #20 on: January 06, 2009, 03:41:41 pm »
arse!! so its:
Ipod and Skoda bluetooth
Fiscon BLuetooth and hard drive music/sd card?
Offline cmdrfire
« Reply #21 on: January 06, 2009, 03:54:38 pm »
As far as I can tell, yes (as the MDI and FISCON Bluetooth require the connections on the back).
I don't have an iPod so it suits me ^^ Fiscon BT and internal HDD.
« Reply #22 on: January 06, 2009, 04:05:44 pm »
fair does, looks like ill have to do that. its probably easier that way anyways
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #23 on: August 25, 2009, 09:29:18 pm »
 Hello all. Just got an RNS510 from the 'Bay. Sorry for dragging this old thread up, but its the only i could find in reference to upgrading from MFD2 to RNS510.
I have dealer fitted MFD2 in my car currently. I have not taken the dash apart to see whats going on behind the unit. However, does anyone expect that i will need anything else other than just the RNS unit itself?
Its a B revision device. My MFD2 is C revision.
#1493
Offline mortygttdi
  • -Receive: 146
« Reply #24 on: August 26, 2009, 06:02:31 am »
This might help cmdfire,  and you Deako you need VCDS go to controller 37 navigation and in one of the setting which is for the MFSW you need to untick it to say its not fitted,  for some reason it conflicts with the setting on the can gateway and you get limited use of your steering wheel buttons.
When I first fitted my RNS I could only use the vol buttons but unticked the mfsw and every thing worked and I have a version E gateway,
I also fitted the Vw premium BT kit and as long has you have a nokia it should work I have the N96 and it works fantastic so much info in there,  when I get a text through it comes up on the FIS and I can do my speed dials on the rns :happy2:
Darren
Offline QD MBE
  • -Receive: 102
« Reply #25 on: August 26, 2009, 06:49:24 am »
I am pretty sure Phil Mcavity also went down this route, from MFD to RNS.  Might be worth dropping him a pm.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #26 on: August 26, 2009, 08:26:00 am »
Darren
I dont have it unfortunately. Just going to plug it in and see how it goes.  :happy2: My car hasnt been coded for MFSW, it just worked without it, so im hoping that thisi will not be an issue.
#1493
Offline shoaybmakda
  • -Receive: 54
« Reply #27 on: January 09, 2016, 04:29:31 pm »
hi all - i know this is a really old thread but I'm doing something similar. my MFD2 isn't factory fitted but I'm debating upgrading to a RNS 5510.
i currently have a iPod dock in the armrest (not the MDI unit) and didn't know if i needed to change the harness to one thats compatible with the RNS and the MDI unit? - this one doesn't charge my iPod (touch) so i wanted to upgrade to the MDI unit instead. i did have a cd changer in my armrest prior to updating to this dock but not sure if the same harness can be used?
my second question is i have the antenna for the GPS on the MFD2 (eBay job) - do i need a fakra wire aswell?
