Author Topic: Had a vcds scan done  (Read 1229 times)
Offline MaxC
« on: March 04, 2017, 03:57:53 pm »
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2472272
   Coding: 0403000318070160
   Shop #: WSC 00488 067 57207
   VCID: 63CE7F73A25DC05994-8036
2 Faults Found:
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 165302 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:49:46
             Freeze Frame:
                    RPM: 2505 /min
                    Load: 9.4 %
                    Speed: 35.0 km/h
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
000665 - Boost Pressure Regulation
               P0299 - 002 - Control Range Not Reached
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 165307 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:56:50
             Freeze Frame:
                    RPM: 3760 /min
                    Load: 90.2 %
                    Speed: 75.0 km/h
                    Temperature: 83.0°C
                    Temperature: 19.0°C
                    Voltage: 14.351 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 408490FF138BBB41A9-8014
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 67D66B635665AC7948-8032
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000002061782
   Coding: E78F8F2700041800001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5ED7538A0D48196C-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00000
2 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 86
                    Reset counter: 20
                    Mileage: 163146 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 11.55 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 86
                    Reset counter: 20
                    Mileage: 163146 km
                    Time Indication: 0
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0JVZYS
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 3776FB234645FCF918-8062
   Subsystem 1 - Serial number: 6332MSME0B04326EB
   Subsystem 2 - Serial number: 6342MSME0C02163D9
   Subsystem 3 - Serial number: 6351HSME08165840%
   Subsystem 4 - Serial number: 6361HSME077C570CI
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000042
   Shop #: WSC 00488 210 71781
   VCID: 76E8362701CF45F1C3-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1212
   Coding: 0007403
   Shop #: WSC 00488 210 91161
   VCID: 6ED81E47799F7D310B-803A
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105812075A
   Coding: 7D3F03C0070003
   VCID: 2A50D25785F7511197-807E
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 22
                    Mileage: 163134 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:08:55
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1212
1 Fault Found:
01176 - Key
            008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2370
   Coding: 0000692
   VCID: 3668F627414F05F103-8062
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 336ECF33523D10D924-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 18C802087F2D8405481FC69010CC
   Shop #: WSC 01287 785 00200
   VCID: 79F23D1B30D12A89AE-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: 74EC0C2F17B357E1FD-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 346CCC2F573317E13D-8060
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
1 Fault Found:
01530 - Radio Mute Switch
            009 - Open or Short to Ground
So last year the car had
New inlet cam
Hpfp
Cam follower
Cam chain
Cam belt
Tensioners
Water pump
Cam position sensor
N205 valve
Checked oil pick up
New oil and filter
Replaced diverter valve only a D revision
Car runs fine with no loss of power.
Thoughts?
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: Had a vcds scan done
« Reply #1 on: March 04, 2017, 04:26:21 pm »
Reset all codes and see what comes back after a few drives. Some codes have to be cleared manually in the selected modules iirc.
Offline MaxC
« Reply #2 on: March 04, 2017, 04:44:07 pm »
That was after reset
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: March 04, 2017, 05:34:09 pm »
Scrap it
