Author Topic: Stage2+ Edition 30s  (Read 6371 times)
Offline robern2
Stage2+ Edition 30s
« on: January 30, 2010, 10:43:05 am »
How many people are stage2+ on their Edition 30s and still running the standard intercooler.
I'd be interested to hear what your current settings are.
« Last Edit: January 30, 2010, 11:12:54 am by robern2 »
Offline Poppa Dom
Re: Stage2+ Edition 30s
« Reply #1 on: January 30, 2010, 11:10:43 am »
Not sure how many replies, you will get, I think most of us on Stg 2+ code are running uprated FMIC's.
Offline robern2
« Reply #2 on: January 30, 2010, 11:12:12 am »
Sure, I'm just curious to see really.
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: January 30, 2010, 11:39:40 am »
i think poverty on here is the only K04 guy running the std IC at stage 2+.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: January 30, 2010, 05:57:24 pm »
Tried it for a while with the Standard IC and found heat soak a bit of an issue on the spirted drives.
The uprated IC made a noticeable difference  :happy2:
Phil Mcavity
« Reply #5 on: January 30, 2010, 09:28:14 pm »
and his engine has gone "Poooofff". Take the warning  :wink:
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: January 30, 2010, 11:10:06 pm »
iirc his settings were pretty aggressigve as well
Offline robern2
« Reply #7 on: January 31, 2010, 09:43:04 am »
I had a PM from him earlier, he suggested he was running boost9 but I wasn't aware his engine/turbo had gone bang.
Offline BenR
« Reply #8 on: January 31, 2010, 11:33:32 am »
Would the standard S3 cooler be classed as an uprated intercooler? I am going stage 2+ also and by the sounds of it I am going to need to get a bigger cooler. Was thinking of the S3 one but would like to hear some advice on that!
Offline robern2
« Reply #9 on: January 31, 2010, 12:09:43 pm »
The S3 intercooler has a larger core than the ed30 so is a useful upgrade, as is the THS intercooler and forge twintercooler.
It's not mandatory for stage2+, factors such as the revo setting,driving style (aggressive, on full boost for long periods of time in different temperature ranges etc) are also considerations.
Personally my spirited driving is very limited in terms of both frequency and duration so for me personally this is less of a consideration but others will disagree.
Offline pako88268
  • Always driving slowly =)
« Reply #10 on: February 11, 2010, 11:48:47 pm »
I'm on stock intercooler with stage 2 + map since yesterday done 500 km  so far
just feeling sometimes fuelcuts or boost cut at high gear cannot tell what it is but still have
to figure out what it cause this. Mods:
TBE Milltek non resonated, Revo Stage 2+, KMD pump, dBilas intake, BSH mounts trans,engine and lower, BSH catch can etc ..
« Last Edit: February 12, 2010, 12:01:54 am by pako88268 »
REVO Stage 2+, Dbilas intake, KMD High Pressure Fuel Pump, Sachs organic clutch, Sachs Single Mass Flywheel, BSH Oil catch tank, BSH Engine mount, BSH transmission mount, BSH lower mount, Milltek downpipe, 200 cells cat back, HKS Turbo Timer, FORGE DV Valve, FORGE Spacer, THS -intercooler, OZ, etc
Offline revo carl
« Reply #11 on: February 12, 2010, 09:07:28 am »
your signature stages a "custom remap"
If you're running Revo and getting fuel cuts I would check your cam follower and log the vehicle to find the fault
Offline NB07
« Reply #12 on: February 12, 2010, 12:08:55 pm »
think he had oettinger before but has recently changed to revo  :smiley:
Offline jonnyc
  • Herrooooo!
« Reply #13 on: February 12, 2010, 12:09:58 pm »
Really???!!
Offline CarrG
« Reply #14 on: February 12, 2010, 12:11:59 pm »
Has it really? Haven't been around for a while.
K1 Revo 2+
Ibis RS3
