Author Topic: OEM "VW Sound System" Amplifier  (Read 3268 times)
Offline loop
  • -Given: 26
« on: March 17, 2017, 10:49:59 pm »
Namely part 1K6035456.
Some Mk5s had this as a factory fitted under passenger seat amp. Can this be installed in cars that didn't have the amp as standard, and if so which wiring harness would you need to connect it to head unit? Thanks
Edit: having done some more research it appears the crossovers are built into the amp so I guess it wouldn't work with cars which have the crossovers in the doors.
« Last Edit: March 18, 2017, 03:14:18 pm by loop »
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Re: OEM "VW Sound System" Amplifier
« Reply #1 on: April 05, 2017, 02:23:39 pm »
Cool, I've been looking for something like that.   What power output does it have?
I would imagine VW crossovers would be a simple capacitor and / or coil affair, which can be cut off easily enough.
Offline loop
  • -Given: 26
« Reply #2 on: April 23, 2017, 10:23:48 pm »
Sorry I have no idea. Apparently they are quite rare, not many Golfs had them fitted in the factory.
Offline SI-R32
  • -Receive: 125
« Reply #3 on: April 24, 2017, 06:43:03 am »
Your right about the crossovers, each speaker output is routed separateley from the amp, so each front door has 3 pairs of cables and rear speakers 2 pairs, so you'll need to route tons of extra cabling through the door plugs, plus door skins off as that's only way to get to door cabling, big project when you can just use a 4 channel amp with existing cable.
I'm pretty sure there isn't a stand alone or after market loom from anyone for such a rare thing to retro fit, hell of a job to give a go.
Offline loop
  • -Given: 26
« Reply #4 on: April 25, 2017, 12:49:39 am »
Yeah had to do some of that recently when I changed my speakers, ran new cabling so the door skins had to come off and had to fit the crossovers under the seats as not enough space inside the doors in a 5 door car. Very time consuming.
