Author Topic: AXX low oil pressure light telling lies !  (Read 802 times)
Offline RaptorRR
« on: March 18, 2017, 04:49:48 pm »
New fully rebuilt engine, new tensioners etc etc etc.   Started the engine and above 1500rpm the STOP low oil pressure indicator illuminates  !
Got over 70 psi of oil pressure with load ,via aftermarket gauge engine sounds perfect and goes well.
Fitted new oil pressure switch. Still the same
So i think its a broken wire, where does the oil pressure wire go to  , ecu harness  ? and if so what is the pin Number.   Tried pining it out and  did not have any luck on both ecu plugs or does it go direct to the clocks.
can someone please point me in the right direction .
