Author Topic: Wheel Bearing Front  (Read 9715 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Wheel Bearing Front
« on: March 20, 2017, 06:55:14 pm »
Got a quote today for Drivers Side Front Wheel Bearing replacement... said it needs to the whole hub and would cost £238 including... ( Edit: TOTAL JOB PRICE, SUPPLY AND FIT, GEN PARTS )
Can't the bearing be replaced without changing the Hub?
If not, is that a fair price for supplying and fitting a new hub with Genuine Parts?
« Last Edit: March 21, 2017, 06:43:35 pm by Scottymon »
Offline ChrisGT
Re: Wheel Bearing Front
« Reply #1 on: March 20, 2017, 07:27:47 pm »
Unfortunately it does have to be the whole hub that's replaced.
Something like 60 or 80 quid for the hub/bearing (sure you can get cheaper ones off ebay but I probably wouldn't...) plus 2 to 3 hours labour at something like 50 or 60 quid an hour then your quote sounds about right.
Chris
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #2 on: March 20, 2017, 07:38:56 pm »
Cheers Chris, hmm, suppose I could call around for a few more prices, but I have a feeling it's going to be around the same.  Going to be a pricey month, four new tyres, discs/pads all round, rear calipers, service and this wheel bearing... ouch.
Thanks for your input (y)
Offline ChrisGT
« Reply #3 on: March 20, 2017, 07:54:15 pm »
Ouch indeed...  :doh:
Always worth getting quotes from a few places.
Chris
Offline Lewo
« Reply #4 on: March 20, 2017, 09:52:46 pm »
From memory when I looked through the old paperwork for my car a rear VW bearing was around £130, can't remember if the fronts were the same, can check for you if you like.
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
« Reply #5 on: March 20, 2017, 10:24:55 pm »
If it's anything like the rears, it takes 45 mins at tops to change.
Front wheel bearing off ECP is circa £90 - £110 dependent on brand you go for.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: March 21, 2017, 01:32:22 am »
That's extortion and I personally wouldn't pay that for a hub from the stealers as Eurocarparts will do the same job for half that price tbh.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #7 on: March 21, 2017, 08:26:01 am »
Just be careful though.....if you buy cheap, you'll probably get speed sensor / abs fault.
It is really common problem with 'spurious' bearings / hubs fitted.  Not made to same high standard.
I think here, I would only use genuine!
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Pesky jones
« Reply #8 on: March 21, 2017, 09:38:48 am »
I bought a hub from eurocarparts for half the price. Then I returned it and bought a genuine one for full price (£130). Difference being the eurocarparts hub (lucas) gave abs and other associated errors. Euros not bad for some things, but not our hubs!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: March 21, 2017, 09:46:05 am »
ow thanks for the head ups  :happy2: didn't think they've be that bad as others have used them but then again we are talking eurocarparts  :doh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: March 21, 2017, 09:47:19 am »
nice one, will think twice about it now  :signLOL:  :stupid:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11 on: March 21, 2017, 04:35:13 pm »
You can buy SKF or FAG. Both make the genuine hubs. Cheaper and same quality. I have a friend that bought a SKF and it had the VW branding too. :laugh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: March 21, 2017, 05:59:26 pm »
I've used skf before but on a different car. :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #13 on: March 21, 2017, 06:35:25 pm »
I should've written that better, it is £238 fitted (using gen parts).
Had a quote from VW themselves, they wanted £359 fitted.
Had another quote with pattern part from VW Specialist for £150 fitted.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #14 on: March 21, 2017, 06:41:26 pm »
Thanks for the response guys
It's going in tomorrow, so I want to see the invoice of the part I'm paying for, I think it's only fair....
Brands to look out for ?  SKF ?
