Author Topic: Is my headlight broken?  (Read 860 times)
Offline sdt492
« on: March 20, 2017, 10:25:03 pm »
This evening the drivers side full beam bulb popped on my '08 Golf Gti. No big shakes I thought as I had a spare H7 in the garage. Popped the cap off the light & as I went to remove the wiring plug I noticed that the bulb & the entire reflector was loose & practically rattling around. Changed the bulb & put everything back as it was and now the full beam is considerably lower than the other side.
Is the headlight knackered or is there a simple fix?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Is my headlight broken?
« Reply #1 on: March 21, 2017, 09:59:57 am »
Put up photos, it sounds like you have a cracked support fixing for the light.
Can happen if you change a bulb in the cold and the plastic cracks. Last owner could have glued it back on and then one bump knocked it loose.
Alternatively, you could have just put it in arseways which isn't uncommon. Getting your hand in there can be a pain!
Offline sdt492
« Reply #2 on: March 23, 2017, 10:38:55 am »
What's the best way to add photos to a forum post on here?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: March 23, 2017, 12:57:11 pm »
Create a photobucket account.
Upload to photobucket.
Copy the IMG link in here.
