Author Topic: R32 full brake setup mk5 ed30 brake line question  (Read 1518 times)
Offline OLLIE_JETTA_MK5
« on: March 29, 2017, 08:26:46 am »
Hello hello
Just won a full mk6 R setup for my ED30
Anybody know what braided hoses I need ? Obviously it's R brakes to ED30 so I think I read they were just longer ? Or are they different fittings etc ? Please help lol
« Last Edit: March 31, 2017, 06:49:38 pm by OLLIE_JETTA_MK5 »
Dubbin it since 2006
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Mk6 golf R full brake setup mk5 ed30
« Reply #1 on: March 29, 2017, 10:08:24 am »
Give AKS a ring. Alex sorted me a set for some 7R/PP fronts.
« Reply #2 on: March 31, 2017, 06:49:05 pm »
Any answer on what brake lines I need for r32 brakes to ED30 ???
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: R32 full brake setup mk5 ed30 brake line question
« Reply #3 on: March 31, 2017, 07:24:14 pm »
R32 brake lines......
« Reply #4 on: March 31, 2017, 07:48:54 pm »
Thats all i needed to know ! cheers pal
Offline Tazocin
« Reply #5 on: April 02, 2017, 06:08:40 pm »
Just a note, depending on your calipers some of the reconditioned ones dont come with the small section of hard pipe brake line that mates to the r32 lines. If this is the case you need to get a slightly different line with a banjo/loop ending (I spoke to HEL and they sorted fronts no problem). Off the shelf r32 lines will have a female-female line which will only connect if you still have the hard brake line in place
Offline v4rley
  • -Receive: 104
« Reply #6 on: April 02, 2017, 06:55:28 pm »
^^^ as another option you can also transfer the hard lines from your stock gti as the figment would be the same
« Reply #7 on: April 02, 2017, 07:10:09 pm »
No you can't. The OEM GTI caliper doesn't have a hardline on the front caliper
Offline Richie-VRS
« Reply #8 on: April 02, 2017, 08:44:46 pm »
I used these braided hoses for my r32 set up which did away with the hard lines. Only thing I had to do was open up the hole on the bracket slightly to get the banjo through.
https://www.ebay.co.uk/itm/400967662276
Offline v4rley
  • -Receive: 104
« Reply #9 on: April 02, 2017, 09:40:12 pm »
I assumed we were talking about the rears  :P
