Author Topic: Wiring to engine bay  (Read 2785 times)
Offline Scoobykiller
« on: March 29, 2017, 04:33:10 pm »
Hi all
Whats best easiest way to get wires to my engine bay?
Where the hole to take through and how tonaccess it
Offline Christiank
  • -Receive: 39
Re: Wiring to engine bay
« Reply #1 on: March 29, 2017, 09:36:27 pm »
Under you're steering wheel behind the CECM module you'll see some cables going through to the engine bay.. Pop your hood remove the battery case and you'll see them coming out.
At least that's the easiest way on LHD cars. Think maybe you don't have to remove the battery box on RHD?
« Reply #2 on: March 30, 2017, 12:00:45 am »
Sorry where do you mean again...
Id rather they come out from the left side somewhere so they come out near the battery and i dont have to have them going accross the bay if that makes sense
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #3 on: March 30, 2017, 08:08:45 am »
if you lift up black plastic strip, along bottom of windscreen.
You'll see a rubber bung, cable inlet by the air intake, covered with mesh grill.
It's for when you have the air quality sensor.
Also another lower down, below the battery, where abs pump is
Push a hole in either one and feed cable will come into passenger footwell
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
« Reply #4 on: March 31, 2017, 02:53:22 am »
What do you mean by cable inlet by the air intake?
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #5 on: March 31, 2017, 08:28:04 am »
http://www.my-gti.com/1267/climatronic-air-quality-sensor-operation-and-location
There is a rubber bung by the side of this, for the cable
Offline Christiank
  • -Receive: 39
« Reply #6 on: March 31, 2017, 03:41:24 pm »
There's so ways .. What do you need cables for/to then I can tell which way is the best for you.
