Author Topic: das 6 pro with meguires 105- small chips after using pad  (Read 1660 times)
Offline croak2012
  • My first Gti mk5
« on: March 31, 2017, 08:55:59 pm »
Hi,
I used das 6 pro today with 105  orange chemical brothers hex pad and it seems afterwards i had some new little white chips . like they were
either touched up before or had something  embedded in the paint removed by pad to produce chip...
I don't really want to keep using 105 because it seems that i need a filler polish rather than a abrasive pad?
i don't really know because no experience of polishing before...
see photo and let me know what your thoughts are ? thanks...
ps .. please don't tell me about practising on sheet metal etc... I am a capable person and don't need all this generic advice... thanks
« Last Edit: March 31, 2017, 08:58:54 pm by croak2012 »
Offline unzippy
Re: das 6 pro with meguires 105- small chips after using pad
« Reply #1 on: April 01, 2017, 01:24:13 pm »
Polish is an abrasive?
Offline croak2012
  • My first Gti mk5
« Reply #2 on: April 01, 2017, 02:13:54 pm »
funny... some remove blemishes and some mask blemishes ...
Offline Chris_R
« Reply #3 on: April 01, 2017, 02:19:37 pm »
Look like they are chips in your clear coat to me and they have picked up the polish causing them to show white.
Get an ear bud and something to clean them out - IPA or similar will do the trick
Offline croak2012
  • My first Gti mk5
« Reply #4 on: April 01, 2017, 02:53:44 pm »
thanks - just used ipa with cotton bud ... yes the white has gone and now the chips are a grey colour .
question - is it just a case of polish with 105 and orange chemical hex pad until chips are gone  or should i use something a bit more abrasive like fine grit sandpaper?
thanks
Ian
Offline Chris_R
« Reply #5 on: April 01, 2017, 09:21:09 pm »
What you have is chips that have broken through the clear but not the colour layer most likely, so to make them "go away" using polishing you would firstly be at it for days and more importantly you will be removing the clear from the areas around it to make them disappear and you DON'T want to do that.
A filler polish won't do the job either, at best, they cover up the odd bit of scratching in the clear by smoothing it out so to speak, they won't fill the marks you have.
Don't worry, it is a common misconception about how much you can fix with even the best rotary and polish etc, they fix minor scratches on the surface of the clear top layer that look bad because they have sharp edges. Polishing basically removes those edges on the deep scratches meaning that they don't reflect the light so much. Minor stuff (holograms, swirls, marring) goes away with hard hard work.
If you look at how your car is painted you basically have (from surface down)
Clear coat, then colour, then primer, then the metal/plastic body panel.
Great example here of the make up:
http://www.theultimatefinish.co.uk/car-care-blog/wp-content/uploads/2011/09/Paint-Defects.jpg
You are basically looking at paint to bring it UP to the level of the surrounding area because you have no clear left to work with in those marks you have. You can imagine if you polish down to them to level them out you are going to have the paint around it also down to the colour coat - not good!
Now the good thing is that providing the colour is intact now you have removed the polish residue, you can possibly get away with dabbing some clear on it using a paint spear. Create a dome that is higher than the current clear by layering it . Then you can use wet and dries (very fine grades still though) followed by refining with compound and polishing to bring it back down to the area around it thus correcting the issue
A kit like this (used them myself to do exactly like I am describing but on full on down to the bodywork chips) will do the job:
https://www.paints4u.com/ProductDetails.aspx?productID=6912
Just be mindful that you are looking for the best result, not a perfect factory fresh finish - which can only realistically be achieved by respraying I am sad to say.
Just remembered there was a guide on Detailing World on this very subject which I followed first time I did it:
http://www.detailingworld.co.uk/forum/showthread.php?t=20127
« Last Edit: April 01, 2017, 09:23:20 pm by Chris_R »
Offline croak2012
  • My first Gti mk5
« Reply #6 on: April 01, 2017, 09:48:22 pm »
thanks,
this clears things up for me !
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: April 03, 2017, 09:51:59 am »
Chris is right!
I recommend getting a filler kit colour matched to your car and then filling each hole afterwards to give a smooth finish.
Your car looks grey? There happens to be a grey touch up kit in the for sale section I believe.
