Author Topic: RCD330G plus issues (vcds log inside)  (Read 3371 times)
Offline spesh
« on: April 02, 2017, 10:36:29 pm »
Fitted a RCD330g plus today along with an updated can gateway.  Fitted the can gateway first to make sure there were no issues and all that went well.
Fitted the RCD330 alright (need a proper aerial connector as I'm only using one at the moment) and it all seems to work alright but I'm getting the following errors.  I assume the aeriel fault is related to the lack of dual to single connector but the rest are beyond me.
Any suggestions?
                Address 56: Radio       Labels: 5M0-035-1xx-56.clb
Control Module Part Number: 6RD 035 187 A    HW: 6RD 035 187 A
  Component and/or Version: MIB2-S-R-CN   025 0210
           Software Coding: 00000400040005
            Work Shop Code: WSC 00081 790 00129
                      VCID: 45815181CC67FF699A-8010
6 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
00625 - Vehicle Speed Signal
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
01336 - Company Data Bus for Comfort System
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 14 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 13:37:48
Offline spesh
Re: RCD330G plus issues (vcds log inside)
« Reply #1 on: April 04, 2017, 10:24:28 pm »
So these issues are caused by the car not having BAP compatible clocks (white ones).  Its not fixable with the red/blue clocks.
pankajet
« Reply #2 on: April 21, 2019, 05:04:31 pm »
Hi,
I am also getting same error for Desay 187B only "00625 - Vehicle Speed Signal ". also navigation is not working properly; arrow doesn't move with Car. But  Noname 187B works fine, no error. Navigation works as well.
pankajet
« Reply #3 on: April 21, 2019, 05:54:02 pm »
What is "BAP compatible clocks " ?
